I am trying to reinstall Presenter 9 after having reinstalled Acrobat Pro Extended 9. I keep getting an error message that powerpoint is not installed and that is not the case. Can anyone help? I recall the last time I did this tech support at Adobe sent me a patch to fix this problem.
Hi there,
Which version of Microsoft Office is installed in your machine.?
Have you ever installed Presenter 9 on this machine earlier?
You may also check this blog if that works http://blogs.adobe.com/captivate/2011/06/adobe-presenter-installation-issues-on-64-bit-operating-sys...
Rajeev.
Yes, Presenter 9 was on my machine in the past. I had to reinstall my OS, which required me to reinstall all my other software. I had 2010, but thought while I was making all these changes I would upgrade to Office 2013. Unfortunately, Presenter will not load on either.
Dr. Ronald D. Flowers
Associate Professor, Educational Leadership
Director Educational Leadership Internships
rflowers@emich.edu
Office: 734-487-0255
Fax: 734-487-4608
Hours: T-W-R 1-5 (After Hour Appointments Available)
You need to check that your Ms Office 2013 is a 32 bit version because Presenter 9 only supports 32 bit version of MS Office 2013. You may check the system requirements here http://helpx.adobe.com/x-productkb/policy-pricing/system-requirements-presenter.html
Also Please make sure that only one version of Office is installed on your machine if there is any previous files and folders exist in your C Drive then you have to remove them manually. also delete the Registry values related to older versions of MS Office.
You need to clean install for MS Office and then try to install Adobe Presenter again in a new user account.
Rajeev .
