Hi all
KCWebPlaza is correct in saying that this is what I was
referring to. I'm posting to say that I hesitate to even mention
that approach for a couple of reasons. My primary reason is that
editing these files likely will result in an exercise in
frustration. Here's the deal. You insert a caption and see you wish
to change the margins. You head out and locate the associated .FCM
file (I think that extension represents "FlashCam Margin") You edit
and make the changes and become frustrated because your changes
aren't reflected in your Captivate project.
This is because when you initially used the caption, all the
caption variants and .FCM files were pulled inside the .CP file.
Thus, the only way to really see the change is to create a brand
new Captivate project, THEN use the caption type. Well, I fibbed a
bit here, as there really is another way. You CAN copy the caption
names and files to a slightly different file name. One that hasn't
yet been used in your project, THEN use that caption type. If you
do this you will then see the changes in place.
Bottom line here is that if you aren't certain about which
caption style you wish to use and you are playing with margins, the
best approach to take is to:
1. Edit the .FCM
2. Create a new blank project.
3. Create a caption and observe the results.
4. Happy? If not, repeat the cycle. If so, open your live
project and use the caption.
Cheers... Rick
