I have Windows 7 Home Premium and IE 11. Have been using Jackie Lawson greeting card app for years. Recently, when I try to access a greeting card within this app, it tells me that I need to install Adobe Flash. After I reinstall Adobe Flash, the same thing happens. I have tried installing Adobe Flash many times including with IE not running and with another app that uses Adobe Flash terminated during the install. I have also uninstalled Adobe Flash prior to beginning the process, but nothing seems to work. Here is the last entry from FlashInstall.log:
2014-12-6+22-17-0.231 [error] 1223 1056
2014-12-9+0-17-0.234 [error] 1223 1056
2014-12-10+1-17-0.230 [error] 1223 1056
2014-12-10+1-17-21.8 [error] 1226 1062
=O====== M/15.0.0.246 2014-12-10+01-17-06.691 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 11
0001 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0002 00000013
0003 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_15_0_0_246_ActiveX.exe
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_15_0_0_246_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_15_0_0_246_ActiveX.dll
0006 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0007 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0008
0009
0010 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0011
0012
0013
0014 00000012
=X====== M/15.0.0.246 2014-12-10+01-17-23.203
Alex Phillips
Hello,
Based on the install log, Flash Player appears to be properly installed. Having you tried the troubleshooting steps on the Installation problems | Flash Player | Windows page?
Maria
Thanks. I haven't yet, but do as you suggest.
Alex
I went to the Installation problems... page. It told me that Adobe Flash is not installed. I checked the Tools/Manage Add-ons and found that Adobe Flash is enabled. I also verified that the Windows id that I am running under has Administrator privileges. Finally, I downloaded the installer from the specified site and terminated IE and the other app that I know of that depends on Adobe Flash and reinstalled Adobe Flash. Same result. BTW - how do I know if all apps that use Adobe Flash are terminated before I do the install??
Alex
Lynne Phillips Dec 17, 2014 7:28 PM (in response to i dont know what to put h)
I am the original poster. Does any one have any idea what I should do next? BTW - this is an Adobe Flash problem: Adobe Flash says its installation has completed, but when the Adobe checker tests for it, it says Adobe Flash is not installed on my PC???
