Agreed, agreed - RH6 is a great upgrade (in that there are
very few problems) but a very difficult one (if you are one of the
people who is affected). Have you ever read "I Had Trouble in
Getting to Solla Sollew" by Dr. Seuss? It might go well with the
margeritas.
And about those darn template replacements - we had that
problem, too, and the solution is silly, but pretty darn effective.
1. Select your topics on the Topics pane.
2. Right-click and select Properties.
3. If <None> shows up in the Template field, go to step
5.
If <Multiple Templates> shows up instead, CHANGE THE
TEMPLATE TO <None>. I swear, it seems like you're going
backwards, but it helps.
4. Click the Apply button, NOT THE OK BUTTON.
5. OK, now select the template you want.
6. Click the Apply button, NOT THE OK BUTTON.
7. Close the Properties dialog with the red X, NOT THE OK
BUTTON.
If you sense a certain theme here, you're right - the OK
button seems to be the culprit. There's also some indication that
changing mixed templates can be dicey. This method worked for me to
change build tags in my 4,000 topic project.
HTH,
Elisa
