I have some ElmScript and want to turn that into an Extendscript, but i have some problems with it.
This is the ElmScript Function.
Sub IHV_Ebene1;
If fslVersionMajor < 3
MsgBox 'Ben'+vsoe+'tigt Framescript Version 3 oder neuer';
LeaveSub;
EndIf
Set PlatformEncodingMode = True;
If ActiveDoc = 0
MsgBox 'Kein aktives Dokument';
LeaveSub;
EndIf
Set gvSrcDoc = ActiveDoc;
GlobalVar gvDocName;
If gvSrcDoc.Name.Count > 0
Set gvDocName = gvSrcDoc.Name;
Else
Set gvDocName = gvSrcDoc.Label;
EndIf
New Book File ('tempXXXX.book') NewVar(gvBookVar);
New BookComponent BookObject (gvBookVar) NewVar(gvBookComp);
Set gvBookComp.BookComponentType = BkNotGeneratable;
Set gvBookComp.Name = gvDocName;
New BookComponent BookObject(gvBookVar) NewVar(gvTocBookComp);
Set gvTocBookComp.BookComponentType = BkToc;
Set gvTocBookComp.Name = gvDocName+'.TOC';
New StringList NewVar(gvExtractList) Value('Ueberschrift 1 Seite BildSeite') Value('Ueberschrift 1') Value('Ueberschrift 1 mehrzeilig BildSeite');
Set gvTocBookComp.ExtractTags = gvExtractList;
Set gvTocBookComp.GenerateInclude = True;
Set gvTocBookComp.InsertLinks = True;
Generate Bookfiles BookObject(gvBookVar) Visible;
Open Document File (gvDocName+'.TOC') NewVar(docobj) ReturnStatus(gvErrorList) Visible;
Open Document File ('O:\Fachanwendungen\Vorlagen\FM9_TOC\ti_toc_ohne2_9.fm') NewVar(QuellDok);
Import Formats DocObject(docobj) FromDocObject (QuellDok) RefPage;
Set ActiveDoc = QuellDok;
Close Document;
Close Book BookObject(gvBookVar) IgnoreMods;
Set ActiveDoc = docobj;
Get Object DocObject(docobj) Type(PgfFmt) Name('Inh-Text') NewVar(NeuFormat1);
Set vPgf = docobj.FirstPgfInDoc;
Loop While(vPgf)
If vPgf.Text <> '<$paranum>\t<$paratext>';
If vPgf.Name = 'Ueberschrift 1IVZ'
Set vPgf.Properties = NeuFormat1.Properties;
EndIf
If vPgf.Name = 'Ueberschrift 1 Seite BildSeiteIVZ'
EndIf
If vPgf.Name = 'Ueberschrift 1 mehrzeilig BildSeiteIVZ'
EndIf
EndIf
Set vPgf = vPgf.NextPgfInDoc;
EndLoop
Set vPgf = ActiveDoc;
Set vPgf.TextSelection = vPgf.FirstPgfInMainFlow.TextRange.Begin;
Set vPgf.CurrentPage = vPgf.FirstBodyPageInDoc;
If vPgf.CurrentPgf = 0
MsgBox 'Keine Einfügemarke';
EndIf
Execute FC CsrTop;
Execute FC HighFlowEnd;
Copy Text;
Close Document IgnoreMods;
Set ActiveDoc = gvSrcDoc ;
EndIf
set vPgf = ActiveDoc.FirstPgfInDoc;
Loop While(vPgf.Name<>'Inh-Ueberschrift')
//Display vPgf.Name;
EndLoop
//Display 'Text: '+vPgf.Text;
Execute Fc CsrTop;
Execute Fc CsrNextBop;
Paste Text;
//MsgBox 'Inhaltverzeichnis generiert'
EndSub
And This is what i came up with so far:
function IHV_Ebene1()
var srcDoc = app.ActiveDoc;
var docName;
if(srcDoc.Name != "")
docName = srcDoc.Name;
else
docName = srcDoc.Label;
var gvBookVar = app.NewNamedBook("tempXXXX.book");
var gvBookComp = gvBookVar.NewSeriesBookComponent(0);
gvBookComp.BookComponentType = Constants.FV_BK_NOT_GENERATABLE;
gvBookComp.Name = docName;
var gvTocBookComp = gvBookVar.NewSeriesBookComponent(0);
gvTocBookComp.BookComponentType = Constants.FV_BK_TOC;
gvTocBookComp.Name = docName+".TOC";
var gvExtractList = ["Ueberschrift 1 Seite BildSeite", "Ueberschrift 1", "Ueberschrift 1 mehrzeilig BildSeite"];
gvTocBookComp.GenerateInclude = true;
gvTocBookComp.InsertLinks = true;
gvBookVar.SimpleGenerate (false, true);
var docObj = OpenFile(docName + ".TOC", true, true, false, true);
var QuellDok = OpenFile("O:\\Fachanwendungen\\Vorlagen\\FM9_TOC\\ti_toc_ohne2_9.fm", true, true, false, true);
docObj.SimpleImportFormats(QuellDok, Constants.FF_UFF_REFPAGE);
app.ActiveDoc = QuellDok;
app.ActiveDoc.Close(Constants.FF_CLOSE_MODIFIED);
gvBookVar.Close(Constants.FF_CLOSE_MODIFIED);
app.ActiveDoc = docObj;
var NeuFormat1 = docObj.GetNamedPgfFmt ("Inh-Text");
var newProps = NeuFormat1.GetProps();
var mainflow = docObj.MainFlowInDoc;
var tframe = mainflow.FirstTextFrameInFlow;
var vPgf = tframe.FirstPgf;
while(vPgf.ObjectValid())
if (vPgf.GetText(Constants.FTI_String) != "<$paranum>\t<$paratext>")
if (vPgf.Name == "Ueberschrift 1IVZ")
vPgf.SetProps (newProps) ;
if (vPgf.Name == "Ueberschrift 1 Seite BildSeiteIVZ")
if (vPgf.Name == "Ueberschrift 1 mehrzeilig BildSeiteIVZ")
var oPgf = docObj.MainFlowInDoc.FirstTextFrameInFlow.FirstPgf;
var oTLoc1 = new TextLoc ( oPgf, 0 );
var oTLoc2 = new TextLoc ( oPgf, Constants.FV_OBJ_END_OFFSET );
var oTRange = new TextRange ( oTLoc1, oTLoc2 );
app.ActiveDoc.TextSelection =oTRange;
app.ActiveDoc.CurrentPage = app.ActiveDoc.FirstBodyPageInDoc;
// If vPgf.CurrentPgf = 0
// MsgBox 'Keine Einfügemarke';
// EndIf
Fcodes([FCodes.CSR_TOP, FCodes.HIGH_FLOW_END]);
app.ActiveDoc.Copy(Constants.FF_COPY_TO_CLIP);
docObj.Close(Constants.FF_CLOSE_MODIFIED);
app.ActiveDoc = srcDoc ;
var tRange1= new TextRange();
tRange1.beg.obj = app.ActiveDoc.MainFlowInDoc.FirstTextFrameInFlow.FirstPgf;
tRange1.beg.offset = 0;
tRange1.end.obj = app.ActiveDoc.MainFlowInDoc.FirstTextFrameInFlow.FirstPgf;
tRange1.end.offset = Constants.FV_OBJ_END_OFFSET;
app.ActiveDoc.TextSelection =tRange1;
// EndIf
mainflow = app.ActiveDoc.MainFlowInDoc;
while(vPgf.Name != "Inh-Ueberschrift")
Fcodes([FCodes.CSR_TOP, FCodes.CSR_NEXT_BOP, FCodes.CSR_NEXT_BOP]);
app.ActiveDoc.Paste(Constants.FF_PASTE_CLIP_TEXT);
if(DEBUG) alert("IHV_Ebene1");
Right now it runs without any error messages. But i don´t get the TOC as wanted. It´s inserting some empty space.
I can see it opening an book and the new TOC File with importing refpage. Then i see him selecting the first row of the TOC File(which is empty btw..?!? ) and trying to paste it.
It is not clear to me what the script is trying to do.
The Script is creating somekind of Table of Contents at the Cursor position.
Can a Forum Moderator pls delete this Topic/Discussion?
