Show 6 replies
1. Re: CS3 can't download the htaccess file
Newsgroup_User Sep 14, 2007 8:18 AM (in response to Mike52179)On Fri, 14 Sep 2007 13:59:38 +0000 (UTC), "Mike52179"
<webforumsuser@macromedia.com> wrote:
>I recently upgraded to DW CS3 and noticed that I can't download a .htaccess
>file. Even if I create the file manually in my local directory, then I click
>GET, DW comes back with an error saying the file doesn't exist on the local
>site.
> I even uploaded from DW then immediately initiated a GET and still received
>the error
> This didn't happen on previous versions of DW, it's new with CS3
> Anyone know of a fix?
I have Dw CS3 and have no problems putting or getting .htaccess.
The only issue with it - is Dw doen't load the file to edit it if you
doublle click.
~Malcolm N....
2. Re: CS3 can't download the htaccess file
Newsgroup_User Sep 14, 2007 9:59 AM (in response to Mike52179)On Fri, 14 Sep 2007 13:59:38 +0000 (UTC), "Mike52179"
>site.
>the error
.htaccess probably cannot exist on your computer since it is an
liiegal filename. I edit mine in UltraEdit, but you could also rename,
download, edit, upload, rename. -
3. Re: CS3 can't download the htaccess file
Newsgroup_User Sep 14, 2007 10:14 AM (in response to Mike52179)On 14 Sep 2007 in macromedia.dreamweaver, Mister Mustard wrote:
> liiegal filename.
In what operating system using what filesystem? Clearly not on most
*nixes; I just opened, edited and saved a file named .htaccess in XP Pro
with NTFS.
Joe Makowiec
http://makowiec.net/
Email: http://makowiec.net/contact.php -
4. Re: CS3 can't download the htaccess file
RustyCT Sep 14, 2007 11:05 AM (in response to Mike52179)If you're using a Mac, files cannot start with a period. I change the name of file on the server, edit the file, then change name back. Don't know if Windows can use a period to start file names.
Hope the workaround helps,
Russ -
5. Re: CS3 can't download the htaccess file
Newsgroup_User Sep 14, 2007 2:19 PM (in response to Mike52179)On Fri, 14 Sep 2007 17:14:17 +0000 (UTC), Joe Makowiec
>> liiegal filename.
>with NTFS.
Clearly most people do not use *nix. :) I do on two computers, but
haven't touched those computers in a month.
I didn't realize XP was okay with that; I've worked around it for
long, it comes automatically. -
6. Re: CS3 can't download the htaccess file
Newsgroup_User Sep 14, 2007 3:29 PM (in response to Mike52179)On Fri, 14 Sep 2007 16:19:37 -0500, Mister Mustard <mustard@hotdog.com>
On my Win2k machine with DW8, I added .htaccess to the open in code view
list in the preferences. When I double-click an .htaccess file, it opens
in code view. I can open, edit and upload just fine.
