I'm having problems with quizzes in Adobe Presenter 10, upon publishing, the text just disappears and the buttons look weird, also the text on submit buttons doesn't show?
I have the same issue..id you find the solution for this?
Yesterday everything was OK. But today I have the same problem inside of all my presentations with questions. Will be glad if someone can explain it….
Hello,
Welcome to Adobe Forums.
I am sending you a .dll file on your email . Please follow the steps given below and see if it resolves the issue:-
Please let me know if you face any issue.
Rajeev.
We had the same issue and this fix worked for us. Thank you.
I am having the same issue, i think. Due to firewall restrictions at my company I am unable to access the Acrobat.com shared file link. Is there any way, Rajeev, for me to send you a private message with my e-mail address?
You may send me your details at my email address rasaini@adobe.com.
Please let me know if that doesn't work.
Rajeev.
Rajeev, I was able to find a workaround to get the file from that location, and now published conent displays fine in IE11, but I still have a multitude of other issues. Javascript issues in IE8, Blank screen in IE11 when running AICC from our Connect Server.
Is it happen with a specific project or any project which you create with quiz.
Did you try to create a sample AICC course and upload it to connect server.
What kind of errors you are getting in IE8. Which output you generating in Adobe Presenter ?
Rajeev.
I created a dummy test project with one slide and two quiz questions. I uploaded to a Connect 9 server for AICC testing.
______________________________________________________________
Publishing as SCORM, running in IE8 gets the following results:
Publishing as SWF gets me the following errors:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; .NET4.0C; .NET4.0E; MS-RTC LM 8; InfoPath.3)
Timestamp: Mon, 11 May 2015 20:53:59 UTC
Message: Expected identifier, string or number
Line: 101
Char: 5
Code: 0
URI:<REDACTED>/data/html/presenter.libs.js
After I close this error, my LMS just churns trying to load SCORM.htm.
Publishing as Both gets me the following errors:
Timestamp: Mon, 11 May 2015 21:07:30 UTC
Line: 1
Char: 467
Code: 0
URI: <REDACTED>/data/html/Project.js
Line: 101
Char: 5
Code: 0
After this error I get an object expected error on the "loadPrContent()" function in the SCORM_utilities.js.
After that it's just a blank page.
___________________________________________________________________________________________________
Publishing AICC to a Connect 9 server, publish as BOTH, Accessing in IE8 gets the following results:
Timestamp: Tue, 12 May 2015 19:19:45 UTC
Line: 1
Char: 394
Code: 0
URI:<redacted>/output/data/html/Project.js
Timestamp: Tue, 12 May 2015 19:21:49 UTC
Line: 101
Char: 5
Code: 0
URI: <redacted>/output/data/html/presenter.libs.js
Timestamp: Tue, 12 May 2015 19:23:00 UTC
Message: Syntax error
Line: 1
Char: 1
Code: 0
URI: <redacted>/output/data/resources/ha/wr_/OpenAjaxManagedHub-all.js
After closing the final error message, I get a blank screen.
Please check the output on any other browser since there might be compatibility issue with this version of browser. Internet Explorer 8 is not a supported browser for Adobe Presenter 10 output.
http://www.adobe.com/uk/products/presenter/tech-specs.html
Rajeev.
