Hello!
I'm trying to update Adobe Flash Player using Safari on a Macbook Pro with OS X 10.10.1 but every time I download the update the file looks like this:
and when I try to start the installation this window appears:
I tried several different download links but non of them worked. I also uninstalled the Adobe Flash Player and tried to reinstall it but then I have the same problem. Any ideas on what I'm doing wrong? Thank you!
For some reason that I have yet to determine, people with Matlab installed start getting .mdlp extensions appended to their downloaded files. That's what happened here. Rename the file to remove .mdlp (so that it ends in .dmg), then double-click the file and it should work.
I really need to make it work...Please.... I'm thankful for any suggestion!
It worked! Thank you so much!
