isValid("string" vs <cfparam type="string"
Engaged ,
Dec 17, 2006 Dec 17, 2006
Just a quick note regarding a difference between isValid and <cfparam, to hopefully help others down the line...
(pay attention to line 5 - it is the difference between the two)
Example #1:
<cfset foo.test = "" />
<cfset bar = queryNew("test") />
<cfset queryAddRow(bar, 1) />
<cfset querySetCell(bar, "test", "bla") />
<cfset foo.test = bar['test'] />
<cfoutput>#isValid("string", foo.test)#</cfoutput>
<cfparam name="foo.test" type="string" />
In example #1, the isValid("string", ...) function does not throw an error, but the <cfparam type="string"... does.
Example #2:
<cfset foo.test = bar['test'][1] />
In example #2, no error is thrown.
As I mentioned, the difference is...
Line #5 in 1st example: <cfset foo.test = bar['test'] />
Line #5 in 2nd example: <cfset foo.test = bar['test'][1] />
If you do not specify the query row number, when accessing a query variable using array notation, isValid() may not throw an error, however <cfparam> might throw an error.
Just an interesting observation.
-Aaron Neff
287
Engaged ,
Sep 15, 2007 Sep 15, 2007
To clarify... If the query row is omitted from the indexed/array notation, then isValid() and <cfparam /> produce different results.
In the attached code example below, the query row was omitted intentionally to illustrate.
Two possible solutions are:
1) Make isValid() throw an error (so that they both throw an error)
2) Make <cfparam /> not throw an error (so that they both do not throw an error)
I feel the behavior should be consistent. Does anyone feel otherwise? If the behavior should be consistent, then which solution, or other solution, is preferred?
Let's discuss!
-Aaron
Documentation
