Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
Logout?
Avatar
Level 2
I want to make sure all the server-side resources are being
cleared upon a Logout operation executed from a Flex application.
Also I want to handle the situation same thing happens server-side
when the user simply bypasses the Logout and kills their browser
window (so the connection with the FDS gets broken).
How to proper implement that on the server?
Trying to mimic the standard http "logout", I used
FlexContext.getFlexClient().invalidate(), but then I realized on
the next Login, FDS will reuse the same FlexClient object, which is
still in the invalidate state (??) hence all the operations
performed with it would fail. Should I try invalidating all the
associated FlexSession instead, so the FlexClient would get
automatically invalidated?
During normal client operation, FlexClient objects have
associated multiple FlexSession objects (http and rmtp). As
FlexSession can have associated multiple FlexClient and viceversa,
I am a bit confused on how to do the logout or handle a broken
connection, server side.
I'm working with the out-of-the box FDS configuration files,
the only things I added are destination definitions for mky Remote
Objects and Data Services.
Thank you.
Avatar
Level 1
Hello Robert,
I have the same problem.
I got a java serverside with a flex client. So at serverside
i created a class that extends AbstractBootstrapService (so it is
loaded as Flex Service from services-config.xml) and it implements
FlexSessionListener interface - listens for sessions created and
closed. But i feel a real lack of knowlege how flexSession works
and how to properly configure it.
At the moment the session destroys (and my SessionListener
class performes all its *user logged off* work ) 5 minutes after
the browser is closed, and i have no guesses how to make it
faster/
Avatar
Level 1
ah, got it, just a <session-config> section in
WEB-INF/web.xml
Avatar
Level 2
You saying your listener method gets called 5 mins after the
Logoff?
Avatar
Level 1
yes, if the browser just closed, without calling *log off*
method, then i listen to destroying sessions, get client id from it
and do log off for this client (clearing serverside data on it and
so on)
i tried to tune timeout setting at <session-config> in
web.xml - but the session still dies only 5 minutes after the
browser is closed.
Avatar
Level 2
You are lucky with your 5 minutes. I just tried with my
environment (LCDS is deployed on Tomcat 5.5), keeping all the
default settings, killed my browser after connecting (I do have
both HTTP and RTMP connections created), and noticed the following:
- the RTMP session was instantly invalidated
- the HTTP session was kept alive for exact 30 minutes, then
it was invalidated (and at that point the FlexClient was also
invalidated, as it contains no more sessions).
I'm looking at ways to set that session timeout value now, to
be less than 30 minutes.
Robert
