When I reset my apple ID and Password for new computer it acts like I have entered wrong password. this happens over and over@
My problem has been solved, thanks anyway.
This password prompt is presented by your operating system, and is intended to keep you from accidentally installing software.
If this is your personal machine and you don't need a password to log into the computer when it first starts up, you can probably leave the password blank and click OK to get past this prompt. If this is your personal machine and your normal password isn't working, check to make sure that CAPS LOCK is off, and type the password carefully.
If this is your work machine and it's asking for an Administrator password, well, you'll need to have a conversation with your friendly IT person.
If you're still stumped, you may need to reset the password on your Mac:
http://support.apple.com/kb/PH18653
I'm having same problem after resetting password & after rebooting system. I can't continue with Avery label maker program without this. Have we been hacked?
Did you take a look at my previous post?
Problem has been solved. Thanks anyway.
