All of our daily users(6) are experiencing the same issue that started last week. They start the publish process and it hangs at a point where it says something about audio conversion and then it closes down and there is no file.
Has anyone found a fix for this?
Hi There,
Are you getting any error while publishing? Try to copy all the slides in a new blank project and try to publish it again. You can also try copying and pasting 5 slides at a time and try to publish to check with slide is causing the issue.
Mayank
