Hello Adobe forum,
looking for the reason why the flash player background update does not work.
Proxy:
fpdownload.macromedia.com and fpdownload2.macromedia.com is white-listed on company proxy.
Verification of whitelist proxy settings -> start cmd.exe as "system account" and downlad xml file"https://fpdownload.macromedia.com/pub/flashplayer/update/current/sau/15/xml/version.xml"
cmd.exe runs as "SYSTEM"
set https_proxy=local_proxy.com:8080
wget.exe -t 1 --no-check-certificate "https://fpdownload.macromedia.com/pub/flashplayer/update/current/sau/15/xml/version.xml"
wget.exe -t 1 --no-check-certificate "https://fpdownload2.macromedia.com/pub/flashplayer/update/current/sau/15/xml/version.xml"
both xml files are successfully downloaded-> this mean no authorization via proxy is necessary because the process runs under "system account".
mms.cfg
SilentAutoUpdateEnable=1
AutoUpdateDisable=0
SilentAutoUpdateVerboseLogging=1
SilentAutoUpdateServerDomain=fpdownload.macromedia.com
registry
this registry I delete before starting update
HKLM\SOFTWARE\Macromedia\FlashPlayer
LastUpdateCheck
UpdateAttempts
after runnig service "AdobeFlashPlayerUpdateSvc" the log says:
2014-12-18+7-57-22.377 [info] 1628 fpdownload.macromedia.com
2014-12-18+7-57-22.377 [info] 1629 fpdownload.macromedia.com
2014-12-18+7-57-22.377 [info] 1614
2014-12-18+7-57-22.377 [info] 1615
2014-12-18+7-57-22.377 [info] 1618
2014-12-18+7-57-22.377 [info] 1608
2014-12-18+7-57-22.393 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/version.xml
2014-12-18+7-57-43.546 [warning] 1403 12002
2014-12-18+7-57-43.546 [warning] 1407 183
2014-12-18+7-57-43.546 [warning] 1408
2014-12-18+7-57-43.546 [info] 1612
2014-12-18+7-57-43.546 [info] 1620
for second test I change mms.cfg
mms.cfg
AutoUpdateDisable=0
SilentAutoUpdateServerDomain=fpdownload2.macromedia.com
runnig service "AdobeFlashPlayerUpdateSvc" again:
2014-12-18+8-0-47.744 [info] 1628 fpdownload2.macromedia.com
2014-12-18+8-0-47.744 [info] 1629 fpdownload2.macromedia.com
2014-12-18+8-0-47.744 [info] 1614
2014-12-18+8-0-47.744 [info] 1615
2014-12-18+8-0-47.744 [info] 1618
2014-12-18+8-0-47.744 [info] 1608
2014-12-18+8-0-47.759 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/version.xml
2014-12-18+8-1-30.222 [warning] 1403 12002
2014-12-18+8-1-30.222 [warning] 1407 183
2014-12-18+8-1-30.222 [warning] 1408
2014-12-18+8-1-30.222 [info] 1612
2014-12-18+8-1-30.222 [info] 1620
Procmon.exe says that FlashPlayerUpdateService.exe is not aware of proxy and goes directly to the source without using proxy.
Time of Day Process Name PID Operation Path
9:02:21,9529004 FlashPlayerUpdateServ... 3472 TCP Reconnect PC_123:54523 -> a92-123-176-236.deploy.akamaitechnologies.com:https
9:02:27,9588431 FlashPlayerUpdateServ... 3472 TCP Reconnect PC_123:54523 -> a92-123-176-236.deploy.akamaitechnologies.com:https
Could you please confirm that FlashPlayerUpdateService.exe is not aware/not support proxy?
thanks
with regards
MB
<moved from Report a problem to Installing Flash Player>
hi team,
exactly the same issue?
could you advise?
