Hi all
Maybe it's just the instructor in me that causes this, I'm
not sure. However, I honestly feel that the worst possible thing
one may do is to intentionally spread misinformation. Because of
this, I decided to ask a "behind the scenes" Captivate resource at
Adobe. Below is what I asked and the answer I received back.
Here is what I asked:
Hi [Adobe resource name]
I need a sanity check if you may.
I know that in Captivate, if I import a .WAV format file,
Captivate converts said file to .MP3 upon importing. I also see
that if I import a .MP3 format file, it converts it to .WAV when
importing. I have always been told that when one Publishes the
Captivate file, the .SWF or .EXE only contains the .MP3 version of
the file. So here's my question.
If I import a .MP3 file into Captivate, it converts to .WAV.
My gut tells me that this is probably because Captivate probably
needs the file to be in .WAV format in order to properly edit it if
I choose. So question number one is to ask if I am correct in my
assumption.
Assume I import a .MP3 and make no changes whatsoever to the
file in Captivate, other than to attach it to a slide or object.
When I go to publish the Captivate file, is the .MP3 modified in
any way going out?
Thanks for any information you may be able to provide.
And here is what I received in response:
It is little complicated but this is how it was designed from
RoboDemo.
1. When a mp3 file is imported to CP, it remains as mp3
unless user edit them. In this case, Captivate will create a wav
file of the same and editing is done on wav file only.
2. Whenever we publish or preview, mp3 file is created and
added inside the SWF file. Thus we can safely say that the output
audio is always mp3.
3. When a wav file is import to cp, it remains as WAV file.
Editing is done as wav format. Publish/Export will create the mp3
from this wav.
So to answer you question, if you import a mp3 file and no
edit is made (not even split into slides) and published, the same
mp3 file will be used in the SWF or EXE. For visual indication,
when you publish, you can notice the text mp3 creation if there is
a need.
Happy Tuesday all... Rick
