ArcIms 9 and CFMX7 problem
Sep 18, 2007 Sep 18, 2007
I just upgraded our cf server from cf5 to cfmx7 on win2003 server and had problem with the existing Esri ArcIMS 9 application. ArcIMS will not run process any web page. CFMX7 runs fine however. Can you help?
Advanced techniques
480
what version of arcIMS? 9.2? what are you using? the cfx tag? see this:
http://www.roktech.net/devblog/index.cfm/2007/3/23/Update-on-the-92-Coldfusion--Connector-bug
if you're using the java connector did you forget to copy the java connector dir
files to cf's class path? btw 9.2, even through 3 service packs, broke the java
connector pretty badly--you might want to stay on 9.1 for the time being.
Hi Paul,
Thanks for responsing. It's ArcIMS 9.0 and I don't use any connector. I googled and found something about CFMX 7 processes all ArcIMS web services after installing but not sure how to stop CFMX 7 from doing that.
not following. cf won't interfere w/arcIMS webservices (not sure what you mean
by "web services"). what exactly is happening?
Sep 19, 2007 Sep 19, 2007
Paul,
After installing cfmx7, none of the ArcIMS 9.0 webpages loads. All users see is a blank screen. I checked all ArcIMS services and they are running fine. If I remove cfmx7, ArcIMS webpages load fine.
what are these "web pages"? html viewers? java viewers? admin apps? do you know?
still not sure what you mean but i guess you're *not* using cf w/arcIMS? you're
*not* running arcIMS under jrun? if so probably a servlet issue, see:
http://support.esri.com/index.cfm?fa=knowledgebase.techarticles.articleShow&d=29356
http://support.esri.com/index.cfm?fa=knowledgebase.techarticles.articleShow&d=25228
btw you *can* run arcIMS under jrun.
Documentation
