quote:
Originally posted by: Newsgroup User
Thanks for all the help. Comments below.
> Thanks, but it:
> 1) Captures everything between the first and last query in a script if there
> is more than one cfquery in the script
Oops: sorry. Stick a question mark after the asterisks to stop the matches
being greedy.
Used this:
<[Cc][fF][qQ][uU][eE][rR][Yy].*?(EventName|AttendeeName)[^>].*?</[Cc][fF][qQ][uU][eE][rR][Yy]>
and got some finds again with multiple queries and some errors as mentioned below.
> 2) It produces some regular expression errors in Homesite.
Can't help you there. Sounds like HS's regex processor is bung: there's
nothing non-standard or tricky about that regex (which might cause
compatibility issues; JS vs PERL vs Java, etc).
HS on the whole is bung (IMO). Have you considered using a text editor
that is... err... *current*? ;-)
No, can you suggest one. Just use HS for years and it does most of what I want.
What sort of errors is it giving?
Regular expression error No 17. Bad expression format or internal error.
> The reason for this is I am developing on a windows machine with mysql and
> want to use the application online on a linux machine where table names are
> case sensitive. My code was not always faithful to that since in windows you
> can be sloppy!
Have you seen this:
http://dev.mysql.com/doc/refman/5.0/en/identifier-case-sensitivity.html
It might be a better approach anyhow.
Adam
> ][eE][rR][Yy]>
> below.
Maybe drop the [^>]
Makes no difference. The original I had still works the best.
Eclipse is probably the best option at present (all still IMO, obviously).
It seems to be where Adobe is applying their efforts for CF and Flex
development.
Not so helpful then. I'm guessing "internal error" more than "bad format",
though.
> Have you seen this:
Did you look at this?
Yes, and I think I know all the alternatives now -- just have to find those problem table names and do the grunt work! Thanks for all your suggestions.
Adam
