Can you use screen capture in Presenter. Barring that, can you use a pointer or other annotation while you narrate?
Presenter has two ways to do a screen capture. Either the Record Video button (poorly named) which launches the Adobe Presenter Video Creator tool which records your screen and your webcam simultaneously, and allows you to edit and output the video after capturing, Or, the Application Simulation button, if you have Captivate installed on the same computer. Both methods can capture the audio narration as you walk through your process.
