The Flash Player crashes every time it tries to load something that requires flash.
It is currently up-to-date, and I have not previously had any problems like this before.
I have a Windows 7, 64-bit system
Running a Firefox browser
I have tried the uninstall/reinstall several times now of both the Flash Player and firefox
As the crash window appears every time, I can't go in to the Flash Player's settings through the regular right-click method.
I found a solution to the flash player crashes within Firefox, and have not had a single flash playser crash in 6 months at least. The solution involves creating a task to run at regular intervals to delete certain prefetch files. NOT all of them as it is NOT necessary to delete them all.
I have wrote a script that will create the folder structer in programdata/scripts/ and place the exe that actually does the deleting, and have successfully imported the task into task scheduler.
That script is not 100% Automated in the above link, but will get you started.
I have one that i have been able to fully automate, You would just need to check task scheduler in Windows 7 to confirm it will successfully import on its own.
I am looking for testers to confirm this works. This should work on windows 7 64 and 32 bit. Not tested on Windows 8
If you want I can post this for you to see if it will resolve your problem?
Best Regards
I have seen this exact post elsewhere, and I was hoping to avoid downloading some script to fix a problem that I haven't had until now.
Good luck on it, as i am the one who made the script , and have had 100% success, but i guess good luck on a fix since this has been going on for years with Firefox and adobe flash
Best Regards
Please, if you wouldn't mind posting the script, I'll try it to see if it works. I would still like to know other solutions that are out there or what exactly would make this problem arise so suddenly.
I am going to post the one where you can open the exe and read the contents of it to see the files. You will need the latest version of WINRAR to open it ( right click open with winrar ).
There is information in the bat files, etc... I urge you to look at it if you feel confident and undetstand it, but please double click the exe when you are ready to install it.
The script will also place a folder on your desktop called Fireofx which is where it will run the bat files. There is also an UNDo script in there to remove the 3 files as well. Once you are confident it is working etc... you can just delete.
We would appreciate any feedback
[Link to executable removed]
Best Regards
I don't think that the script did what it was supposed to, that or, I'm not entirely sure how to properly run it.
Just double click on the exe file you downloaded , thats it. a black cmd window should open and then when its done it will say success and then just press any key to close it
It did not say success, and I am unsure how I can trust someone using an account made yesterday.
Then dont trust me and be on your way
No attempt to try and troubleshoot your own program?
You are unsure if you trust me. The program works flawlessly on my machine. I am on Win7 64 bit as well. Right click on my green icon and run as administrator
Is there a Firefox folder on your desktop ?
Yes, there is.
OK, GOOD! and you are saying that after you ran as administrator a black window didnt open up and run and then pause and something like this below didnt show?
SUCCESS: The scheduled task "Clear Firefox Prefetch" has successfully been creat
ed.
C:\Users\Carm\Desktop>pause
Press any key to continue . . .
No, at the end, there's an error that reads
ERROR: No mapping between account names and Security IDs was done.
Alright, my bad, my bad I was referencing my desktop not any user who uses it in the script.
Re-download it, and it should now work for you.
Sorry
https://www.dropbox.com/s/dsxjjpexrvvnne9/Firefox_Flash_FIX%28x86%29.exe
I've got a Success message now. Is there something else I need to do?
AWESOME!
NO there is nothing you need to do. The script works in the background and you will never notice it ever.
If you want to look at what it did you can open the firefox folder and click on task scheduler, then in the left pane you will see " Task Scheduler Library" just single click on it ( highlight it ) and in the middle pane you will see that task, and you can look at that if you so choose, and the actual files that do the deleting are located in: C:\ProgramData\Scripts.
You should not have to do anything its done.
IF you so choose to undo everything there is a file in the Firefox folder called Undo. that will delete the task and the folder and two files.
Thank You for you Patience and I am hopeing to hear back some positive results of zero crashes for flash player so this can help other out too.
Best Regards
Flash still crashes, though..
Close it and re-open it
I've closed and re-opened Firefox a few times
Open C:\Windows\Prefetch
Look and see if there are two files in there that look like or start with: flashplayerplugin and PLUGIN-CONTAINER , and delete them
I can't find either of those files.
OK that means the script is deleting the files, but you are still having flash player crashing?
You have made no additional modifications to Firefox or flash ?
Do you have any Firefox Bookmakrs to save and completely delete firefox including setting and re-install from scratch?
