But the TAB only allows you to go down. What if you shoot by
the book you need? There doesn't seem to be a way to tab up. The
latest WebHelp I generated has this issue. Our previous help, in
Flash, had no problems at all.
So there is *no way* to use the arrows? To me, that's
peoples' first thought. Plus, the arrows work fine in FlashHelp.
Can you just let me know if "there is NO WAY to use the arrows,"
because then I'll stop looking for it. Thanks.
Keep in mind that with FlashHelp, you are interacting with
the TOC in a way that is worlds apart from WebHelp. With WebHelp,
you are interacting with typical browser components. With
FlashHelp, you are actually interacting with a Flash object that is
sitting where the TOC pane is.
