I have a form in drop down that I built in BC than took the HTML code to Dreamweaver in order to place the form in to a two column table. I was told by the BC support that a JS that required the fields to filled in is required. Not sure how to do that, please help.
Hey there,
That does not make to much sense. By default when you create a BC form and mark fields as required in the admin it should already come with javascript for form validation
That is what I thought. But i figured out what I did wrong. I used a custom field for First and Last Name rather than the BC Field. Once that was replaced it worked great. Thanks Liam.
