[Stage3D]The ATF compress texture quality loss in some phone.
Dec 30, 2014 Dec 30, 2014
Left picture is original. On the right is to use the ATF compress texture.
I used the command png2atf.exe -c e -q 0 -n 0,0 -r -4 -i "in.png" -o "out.atf"
The phone use android system 4.2.2 and CPU model is MT6592(GPU is "Mali 450 MP4").
ActionScript
5.6K
Explorer , Aug 02, 2016 Aug 02, 2016
Issue seems to be fixed in AIR SDK 23.0.0.215.
Tested on following devices:
LG Nexus 5X
Huawei G7 Plus
OPPO R7s
Samsung Galaxy S6
Samsung Galaxy Edge+
HTC One E9PLUS
Engaged ,
Dec 31, 2014 Dec 31, 2014
Try to use: png2atf.exe -c e -q 0 -n 0,0 -i "in.png" -o "out.atf"
Jan 20, 2015 Jan 20, 2015
I find the same problem, But my device is Samsung Note4 (CPU Exynos5433 GPU Mali-T760)
if I use the '-r' parameter, the texture is abnormal
remove the '-r' parameter, the texture is normal, but the ATF file is too large, difficult to download from game server.
so I want to have another method, use LZMA compress only, do not use JPEG-XR compress.
cheers.
thank you for reply. how use LZMA compress only?
This is a good wish
Guest
Mar 03, 2015 Mar 03, 2015
it's really a big problem in our project
without -r , the atf ByteArray memory will be 10 times larger
I have a test on a 2048x2048 atf
use -c -r will takes about 6M gpu memory and  350K normal memory on ByteArray
use -c only, still 6M on gpu but 4M normal memory on ByteArray
if it's a bug on atftool hope abobe will fix it soon
or anyone could tell me a good way to use atf without memory waste
Mar 16, 2015 Mar 16, 2015
so far has not been repaired.
May 28, 2015 May 28, 2015
Get this bug too, on Samsung devices that uses Mali GPU. Is there are any solution for this bug? Maybe ask Adobe add option "Disable XR JPEG" or use the alternate compession to png2atf tool? On Github i found sources for the dds2aft tool, and maybe Adobe can open their code of png2atf? It will be GREAT.
PS. I don't know if Adobe members reading this topics, so it will be nice if somebody know how to contact them.
Aug 23, 2015 Aug 23, 2015
Hi melkosofter,
I'd like to know which Samsung devices you are using? thx
Aug 26, 2015 Aug 26, 2015
Hi! I saw this bug on
Samsung Galaxy Alpha
Samsung Galaxy Note 4
Meizu mx4
But there are devices which probably have the bug too
Samsung Galaxy S5 (octa-core) (exactly octa-core, not just s5)
Samsung Galaxy S5 Neo
Samsung Galaxy Tab S 10.5
Samsung Galaxy Tab Pro 10.1
Samsung Galaxy Note Pro 12.2
I have alike problem on
MT6752 (GPU=Mali T760)
MT6795 (Meizu mx4, GPU=IMG)
No problem on
Samsung note 3 (Qualcomm Snapdragon 800)
HTC butterfly (Qualcomm S4 Pro APQ8064)
MI pad (CPU=NVIDIA Tegra K1)
MI2S (Qualcomm Snapdragon 600)
May 30, 2015 May 30, 2015
i find a solution.
don't use "-r -q and  -4".
just use -n 0,0(if you not used mipmap)  and -c e.
png2atf.exe -c e -n 0,0 -i "xxx.png" -o "xxx.atf"
ok. have a problem: the atf file will very big.
but you can use tool compression the ATF. The compression ratio is very high
when you loaded in memory get a ByteArray. use ByteArray.uncompress() method get the raw data.
upload to GPU will rapid.
when you uploaded to GPU, don't forget call ByteArray.clear();
Dec 18, 2015 Dec 18, 2015
Issue still persists in AIR SDK 20.0.0.225
Jan 04, 2016 Jan 04, 2016
Still reproducible on LG Nexus 5X after rebuilding ATFs with 20.0.0.233, setting app namespace to 20.0 and swf-version to 31
Feb 03, 2016 Feb 03, 2016
Still reproducible with AIR SDK 21 Beta
Feb 14, 2016 Feb 14, 2016
i really wish Adobe members fix the problem.
Feb 15, 2016 Feb 15, 2016
I'm now waiting for the next beta to test - Bug#4041690 - ATF texture is corruption on MALI GPU platform
Feb 18, 2016 Feb 18, 2016
The issue is still reproducible after rebuilding ATFs with 21.0.0.150, setting app namespace to 21.0 and swf-version to 32.
Device is LG Nexus 5X.
Mar 10, 2016 Mar 10, 2016
Issue is still reproducible with AIR SDK 21.0.0.176 released today
Apr 11, 2016 Apr 11, 2016
Issue is still reproducible with AIR SDK 22.0.0.89
May 26, 2016 May 26, 2016
Issue is still reproducible with AIR SDK 22.0.0.149 released today
Jun 20, 2016 Jun 20, 2016
Issue is still reproducible with AIR SDK 22.0.0.153 released last friday
Jul 27, 2016 Jul 27, 2016
I'd love to see this fixed.
LG Nexus 5X
Huawei G7 Plus
OPPO R7s
Samsung Galaxy S6
HTC One E9PLUS
Aug 31, 2016 Aug 31, 2016
you are really good man.
Thank you keeping track of this topic.
