Seems funny that people are suggesting to use a seperate
recorder to do this as it defeats the purpose of using presenter
and connect. Presenter is suppose to cut down on the time of
synching the audio to the slides, you might as well just go back
and do this in flash/xml solution pulling in timing and slides.
We have the same problem here but we backed up the ppc file
before editing it. It deletes the ppc file for some reason even if
we tried renaming the ppt and repointing it to the ppc file. Also
tried renaming ppt and recording new ppc and then renaming old ppc
to this name. Same behavoir, it gets deleted.
Upgraded to 6.2 and retried but no such luck.
Is there file size or time limitation in presenter? Obviously
it can record 6 hours, which I have done but some people on the
forum said that there is an upload limitation of 100mb when this
gets converted. Is this only in the old breeze or does this still
exist?
And if it does, shouldn't Adobe point a big yellow yellow! in
their guides, documentation, and getting started tutorials?
Anyhow, I put in a support ticket with Adobe. I hope this
gets fixed.
