1. Re: Activation Error
read2live99 Sep 22, 2012 11:39 PM (in response to CarolynFPW)i'm havoing same problem, did you ever get this resolved?
2. Re: Activation Error
wilfried101 Nov 6, 2012 8:39 AM (in response to read2live99)I´m getting the same problem. My computer was activated. By trying to activate my ebook-reader my computer losts its activation and the same message "Activation Server Error: Code E Auth not ready" appears. Can somebody help to solve this problem.
3. Re: Activation Error
sandy25277 Nov 8, 2012 12:00 PM (in response to CarolynFPW)i am getting the same message is their anyway of fixing this?
4. Re: Activation Error
gullimugg Nov 8, 2012 12:21 PM (in response to CarolynFPW)3 people found this helpfulYes there is a way of fixing this. Probably you have just installed ADE 2.0 (and uninstalled ADE 1). If so you had already authorized your computer with Version 1 but Version 2 does not recognize this.
So open ADE. Hit Control-Shift-D. This will ask you if you want to get rid of the authorization on this computer.Answer "Yes". Then try again to authorize this computer and this time it will work.
5. Re: Activation Error
Derek Leng Nov 8, 2012 7:30 PM (in response to gullimugg)One note here just in case. If you borrowed any book from library, Control-Shift-D will remove your loan record. You may have to re-borrow them from library.
6. Re: Activation Error
atoca Jun 16, 2014 5:55 AM (in response to gullimugg)Deleting the prior authorization and then reauthorize worked for me, thank you!
7. Re: Activation Error
drdwheelerreed Nov 2, 2014 7:28 AM (in response to CarolynFPW)Just a brief note... on a Mac it's Command+Shift+D
d
8. Re: Activation Error
imintrouble Dec 30, 2014 6:08 AM (in response to gullimugg)Thank you so much!
9. Re: Activation Error
lapeet Jan 6, 2015 10:05 AM (in response to gullimugg)I have the same problem: an error message that my PC is not connected to the Internet. I tried Ctrl-Shift-D and nothing happened. So what next?
10. Re: Activation Error
Nessa1 Jan 6, 2015 4:15 PM (in response to lapeet)I have been having the same issue since the last week of dec and I have yet to get an answer or any help for that matter. Everytime I try to authorize ADE is tells me it cant connect to the server and to check my internet connection. Its very frustrating.
11. Re: Activation Error
NO PUEDO AUTORIZAR MI EQU Jan 7, 2015 7:11 AM (in response to Nessa1)Hi,
I have the same problem. Someone can help us????
12. Re: Activation Error
zuzolo Jan 7, 2015 7:27 AM (in response to CarolynFPW)i have the same problem, anyone?
13. Re: Activation Error
ChrissieJL Jan 14, 2015 7:30 AM (in response to gullimugg)Thanks, worked for me too! Wasted so much time yesterday and today.
14. Re: Activation Error
lapeet Jan 14, 2015 9:02 AM (in response to ChrissieJL)What is it that worked for you? I receive the message that my PC is not connected to the Internet and have tried to use Ctrl+SHift+D without luck.
15. Re: Activation Error
ChrissieJL Jan 14, 2015 9:08 AM (in response to lapeet)Hi, it was the ctrl/shift/D that worked for me. I am still having problems though with transferring books from my ereader.
16. Re: Activation Error
trepuntisospesi Jan 31, 2015 3:27 AM (in response to gullimugg)great!!!!
I feared I would waste a lot of time but... Luckily there was you!!!!thank you indeed!!
17. Re: Activation Error
canadianbeth Oct 13, 2015 8:20 AM (in response to trepuntisospesi)I still cannot transfer books to m y e-reader. I tried the shift-control-D and did finally get ADE authorized but still get the copy not allowed. I cannot believe the runaround I have been getting since the 1st of this month when I purchased 9 books. Ever since then I cannot load them onto my reader; in fact everything on it disappeared and I now have to re-load dozens of books instead of just the few I bought last week. No one seems to care or know how to help me; not the book publisher, the e-reader company or Adobe. They all just tell me to talk to the other entity. I do not know what to do next.
18. Re: Activation Error
Ronnie McGovern Nov 6, 2015 8:06 AM (in response to gullimugg)many thanks for giving us this solution! I have been getting driven daft for months trying to sort it. many thanks again.
Neil
19. Re: Activation Error
Luis Cuetos Nov 6, 2015 7:33 PM (in response to CarolynFPW)After requesting to erase the authorization I get "unable to Erase Authorization. Please try after some time" message, even after waiting hours before re trying.
Any advice?
20. Re: Activation Error
Nanaky Nov 7, 2015 1:09 AM (in response to Luis Cuetos)Do you used Windows or Macintosh?
22. Re: Activation Error
Nanaky Nov 7, 2015 4:36 AM (in response to Luis Cuetos)Quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see Access hidden library files | Mac OS 10.7 and later.
Open Adobe Digital Editions and reauthorize.
23. Re: Activation Error
Luis Cuetos Nov 7, 2015 5:21 AM (in response to Nanaky)Perfect, Thanks a lot
It worked fine
25. Re: Activation Error
佳周34092499 Nov 8, 2015 1:58 AM (in response to Nanaky)I am encountering this same problem. After requesting to erase the authorization I get "unable to Erase Authorization. Please try after some time" message, even after waiting hours before re trying. This is very frustrating! I have wasted a lot of time for repeating this same process!
Any advice?
26. Re: Activation Error
Nanaky Nov 8, 2015 10:57 PM (in response to 佳周34092499)Do you used Windows or Macintosh?
27. Re: Activation Error
佳周34092499 Nov 9, 2015 12:17 AM (in response to Nanaky)I use Macintosh, Apple MacBook Pro. Thanks!
28. Re: Activation Error
Nanaky Nov 9, 2015 1:56 AM (in response to 佳周34092499)Quit Adobe Digital Editions.
29. Re: Activation Error
佳周34092499 Nov 10, 2015 7:03 AM (in response to Nanaky)problem solved! thanks very much for your help! all the best!
31. Re: Activation Error
lyndat97987110 Apr 23, 2016 11:50 AM (in response to CarolynFPW)Control-Shift D works... thanks
32. Re: Activation Error
Nanaky Apr 24, 2016 11:24 PM (in response to lyndat97987110)You are welcome.
33. Re: Activation Error
maryl29798705 Sep 19, 2016 1:08 PM (in response to CarolynFPW)I struggled with this for days, tearing my hair out. Found a simple solution. I uninstalled Adobe digital 3.0 from my computer. Then I downloaded Adobe Digital 4.0. Adobe 4.0 let me deauthorize my computer. Then I uninstalled Adobe digital 4.0 and reinstalled Adobe Digital 3.0 I could then authorize my computer.
