In Captivate 6, when doing the initial timings edit for audio or video is there a way to grab all the slide markers (yellow bars) and drag them together downframe? I have an hour-long piece with 69 slides that requires dragging each one individually. This seems such an un-user friendly way to set your initial timings that I figure I must be missing something...? Thanks
Hi there
Can you post a screen shot? Not sure I grasp what you mean when you say "yellow bars".
Cheers... Rick
Here's a screenshot after importing audio and starting to set up the slide timings-
It would be great if there was a way to just select all these and drag them to the end, rather than having to do each individually (very time consuming).
Ok, I figured out a better way to bring in audio that groups the slides at the end rather than the beginning, which was happening above. However, I still can't figure out how to do the same for video. No matter what I do, the slides are all bunched at the beginning, which means dragging each individual slide to the end to give room for editing.
