We want to deploy flash player with silent background updates enabled. To test the update mechanism I installed version 13.0.0.258 activeX and let it auto update.
I expected it would update to version 13.0.0.259, but version 15 was installed.
How can this be, I thought 13 is still the extended support version?
below mms.cfg and the install.log.
mms.cfg
AutoUpdateDisable=0
SilentAutoUpdateEnable=1
SilentAutoUpdateVerboseLogging=1
FlashInstall.log
=O====== M/13.0.0.258 2015-01-08+08-35-07.117 ========
0000
0001 00000010 "C:\Users\Administrator\Desktop\ClientDate-IE-flash\install_flash_player_13_active_x.exe" -install
0002
0003
0004 00000011 1
0005 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0006
0007 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_13_0_0_258.ocx
0008 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_258_ActiveX.exe
0009 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_13_0_0_258_ActiveX.dll
0010 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0011 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0012 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
=X====== M/13.0.0.258 2015-01-08+08-35-15.564 ========
2015-1-8+8-40-20.506 [info] 1614
2015-1-8+8-40-21.99 [info] 1615
2015-1-8+8-40-21.365 [info] 1618
2015-1-8+8-40-22.428 [info] 1619 1063
2015-1-8+8-40-22.724 [info] 1614
2015-1-8+8-40-22.724 [info] 1615
2015-1-8+8-40-22.724 [info] 1618
2015-1-8+8-40-22.740 [info] 1608
2015-1-8+8-40-22.740 [info] 1604
2015-1-8+8-40-22.787 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/version.xml
2015-1-8+8-40-26.537 [info] 1630 /pub/flashplayer/update/current/sau/11/xml/patch.xml
2015-1-8+8-40-28.162 [info] 1600
2015-1-8+8-40-40.240 [info] 1602
2015-1-8+8-40-40.240 [info] 1609
2015-1-8+8-40-40.240 [info] 1612
2015-1-8+8-40-40.271 [info] 1620
2015-1-8+8-41-16.990 [error] 1226 1062
=O====== M/15.0.0.246 2015-01-08+08-40-41.943 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 9
0001
0002 00000011 1
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004 00000013
0005 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_15_0_0_246_ActiveX.exe
0006 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_15_0_0_246_ActiveX.dll
0007 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0008 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0009
0010
0011 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0012
0013
0014
0015 00000012
=X====== M/15.0.0.246 2015-01-08+08-41-19.053 ========
We launched the ESR to provide pain relief for network administrators, but it came long after the background update service was built, and it's not currently designed to handle multiple parallel branches. Supporting the ESR via background update is on our product backlog, but it's not likely to get done for a while. Just getting the ESR was the first battle, and we're making incremental improvements as time allows.
The really big organizations that we were targeting with the ESR typically run t
...Copy link to clipboard
The really big organizations that we were targeting with the ESR typically run their own in-house auto-update servers or they push all updates through their own management tools (AD/SCUP/SMS/etc). Those organizations typically have onerous testing requirements for distributing feature-bearing updates, so the ESR was really designed to minimize the testing burden on those IT departments -- streamlining the distribution is something we want to do, but it was more important to just make it available as an option for distribution.
You can find details on running your own auto-update server in the administration guide, but it's non-trivial and we're still working out the kinks (notifications slip through in some edge-cases, etc). There's also a good rundown on the customization options for various updates. You may be better off using your standard software management tools to distribute updates in the short-term, depending on your environment's complexity and available resources:
Adobe Flash Player Administration Guide for Flash Player | Adobe Developer Connection
Thanks for the helpful information, Jeromie.
Just one more thing: Do you still announce esr updates here Flash Runtime Announcements ?
If not, how can we learn about a new esr version release?
Best Regards
Manuel
edit: maybe for your next admin guide you want to add a notice at the update section that esr is not supported yet
That's a really good point about the docs.
Guidance on the ESR is included in the release notes and the security bulletins for each release, but the long and short of it is that you want to always use the latest available version of the ESR branch. Normal releases happen monthly, on Patch Tuesday. Out-of-cycle releases happen as needed (i.e. we've seen an exploit in the wild) and we'll publish security bulletins and guidance about those.
If and when we change the ESR branch (in recent history this has been driven by the needs of the infrastructure), we try to provide as much lead time as possible and will announce in the forums and will typically post a blog post. The distinction being that we control the content in the forums directly, but everything else has to go through intermediaries.
I'd recommend that you sign up for the Adobe Security Notification service. Whenever patches with security impact for Adobe products become available, you'll get an email.
