I've tried everything since last week, including re-install, clean install, install direct from Adobe web site, downloading offline, etc,. Everytime my installer stops at the middle of the way and I keep get an error message - “Error: General installation error”. Please help!
Please use the offline installer:
http://fpdownload.macromedia.com/pub/flashplayer/latest/help/install_flash_player_osx.dmg
I tried but It is not working. Got failed message "This installation failed. Get support"
Have tried the offline installer for many times and got the same result, please help!
Have tried the offline installer for many times, it doesn't work for me. Here is the Screen Shot I got, please help!
Here's what I recommend:
Run the disk utility section described here first:
Resolve startup issues and perform disk maintenance with Disk Utility and fsck - Apple Support
Then I would recommend doing a clean install:
If you're unable to do this, boot into Safe Mode as described by the Apple link above, and try again.
I've you're still unable to proceed, let me know.
Good luck!
Hi I have tried all of that and still get the same results. Is there anything else I can do? Since I've uninstalled the flash player I can't even get the old version to run like I use to.
