Hi
I'm using the Java Advanced Imaging API since CF6 and made
several jar files to manipulate images (as it wasn't integrated in
CF).
Today I installed CF8, put the "jai_core.jar" and
"jai_codec.jar" in the "cfroot\runtime\jre\lib\ext" folder as I did
when I first developped my application or when I migrated from CF6
to CF7 but today it does not work.
I have the following error (see attached), ImageInfo and
GetTaille are my own jar classe and method.
I saw that there is already a "jai_core.jar/jai_codec.jar" in
"cfroot\lib" So I think that there is a conflict between the two
JAI's. I removed mine, but I have another error : "An exception
occurred when instantiating a Java object. The class must not be an
interface or an abstract class. Error:
com/sun/media/jai/codec/ImageEncodeParam."
I also tried to replace the JAI of CF8 by mine (just for a
test) but I have the same error.
Do you have any idea of a solution ?
I know I can now use the CF8 tags to manipulate images, but I
have to rewrite lots of code and I think there is still
manipulations that CF8 can't handle (CMYK images, ICC profiles,
Thanks in advance for your suggestions
