what do you mean by "open up command line"? I am getting this 42001 error and would love to be able to publish my presentations. Thanks!
I get a DllRegisterServer "failed". Return code: 0x80070005
I know this is from 2010 but I just started with a company that uses this software and we are receiving this same error. I tried doing the regsvr32 ppsuplo.dll but came back with the following result " The module "ppsuplo.dll " failed to load. Make sure the binary is stored at the specified path or debug it to check for problems with the binary or dependent .DLL files. The specified module could not be found. I then looked in the program files folder for presenter and found the file right there. Then tried using the repair option without any luck. Anyone have an idea of what else we can do?
