(Captivate 3) In the same recording session I need to be able
to show powerpoint slides and discuss items, and then go to a
different screen (web in this case) to demonstrate how something
works. I need to go back and forth between the .ppt and web screen
several times during the demo. What is the easiest way to
accomplish this? THANK YOU!
When you record something using Captivate, you basically see
a red recording rectangle on the screen. The thing is, Captivate
records whatever happens inside that area. So you may continue to
press Alt+Tab to move between applications and Captivate records
each application as it appears inside the area.
Thanks. I tried the Alt Tab routine earlier but it makes for
a relatively ugly look for the viewer who sees all of this
happening. Maybe that's all that there is, but I thought I'd ask
again. THANKS for the quick reply.
The actual process of switching via Alt+Tab will likely
result in having screens showing the process of switching. Keep in
mind that you are free to remove those unwanted screens after you
create your demonstration/simulation so the end user never needs to
see them. Instead, you could insert a blank slide that serves as a
segue into the next segment.
Thanks again. I will follow your advice. I was just hoping to
avoid having to go through and edit out all the Alt-Tab screens but
it can be done. Cheers, Gary
Hi Gcsheph,
You can also import your powerpoint slides into the project
instead of recording them. Record the stuff you need to demo on the
web, then go into the project and insert the PPT slide into the
appropriate places. Then you do not need to use Alt+Tab and edit
out the extra stuff. Since you are using Captivate 3 you can import
the animations on your PPT slides.
Peter
A good idea here. The only possible issue is the chatover but
it could be recorded and inserted after the slide is put in, the
only problem being keeping the train of thought going for the
overall demonstration. Thanks for your idea. Gary
