Can I make bookmarks invisible?
Jan 12, 2015 Jan 12, 2015
RoboHelp HTML 11, output Multiscreen HTML5.
I wondered why some of the text in my project output was green instead of black, but I finally realized that these are bookmarks. Is there any way to make bookmarked text look like ordinary text?
564
Hi there
I'm assuming that you mean you don't want to see it during the editing process, right? Because hopefully you know that the text is only green while you edit. When you generate the output, the text should be the same color as the rest of the text.
Actually, it sounds like you are taking the wrong approach to bookmarks. Instead of selecting text and making the selected text a bookmark, I much prefer to leave all text unselected and simply insert a bookmark. This should then produce a little flag icon that can easily be repositioned if you need to move the bookmark.
Another advantage to this approach is that clicking View > Show > Bookmarks will actually hide the small flags.
Cheers... Rick
Actually, I was mistaken: it's reddish-brown, not green. (My color vision is impaired.). But it is definitely not black, and it is definitely in the output. as well as the editing screen.
Also, I'm not the one who put the bookmarks in: RoboHelp did. When I linked in a Word document, every heading and figure caption comes out as a reddish-brown color. (Well, almost every heading and caption. Some are partly skipped.)
I tried un-checking View > Show > Bookmarks. In the editing screen the bookmarks change from green (or whatever) to blue. In the output, it's still reddish brown.
Any thoughts?
Can you please share some screen captures?
One with the text in the RoboHelp Editor.
Select the bookmark and change the Editor to HTML view and give us a screen capture of what you see there
One with the text in the ouptut
Thanks... Rick
Jan 13, 2015 Jan 13, 2015
If the problem is what I think it is, in Word there may be a TOC that is linked to heading styles. Word then makes the text a bookmark so when Rh receives the Word output it not unreasonably gives you the same setup. Try importing a simple document from Word with heading but no TOC and no bookmark.
@petergrainge
Peter, you seem to be onto something. The linked Word document does have a Table of Contents, and when I remove it, the problem does go away.
Now, is there a way to solve the problem without removing the Word Table of Contents?  (I may need it for the Printed Documentation version.) Excluding it with Conditional Tags doesn't help.
Nice catch, Peter!
I realized that some of the colored bookmarks remain, because there are references to them in the text. In other words, removing the Table of Contents only solves part of the problem.
I'm still waiting for permission to send those screenshots. How would I do that on this forum?
Use the camera icon in the web interface.
When you do the import, deselect the TOC.
See Importing on my site.
I'm not importing, Peter, I'm linking. Does that make a difference?
In either case, deselecting the TOC is only solving part of the problem; I still see bookmarks created in Word by cross-references.
I'm seriously considering changing the color of the heading text from black to green; that way the bookmarks won't stand out!
Surely there is some CSS or even a style in Word that would govern this, no?
Jan 14, 2015 Jan 14, 2015
@rick I'm not seeing how the bookmark itself is showing at all, never mind what colour. I have a hunch as to what the problem might be, see below.
@shawnvw Please post an image of what you see in the generated help.
@petergrainge
This is the output. All the header text should be black.
I'll certainly defer to Peter as to the Word stuff. Especially as he has a hunch about it.
But it sure looks to me as if over in Word world, there has been some style applied that configures those colors. It would be interesting to see the CSS files involved.
RH conversion - AMHS.css
RHStyleMapping.css
Note that you can open these in Windows Notepad, then copy what is inside and paste into the forum reply.
Cheers... Rick
Here's the first one:
RHStyleMapping.css
/*Created with Adobe RoboHelp 11.*/
p.BodyLevel1 {
margin-left: 18.000pt;
margin-right: 0.000pt;
text-align: left;
text-indent: 0.000pt;
margin-top: 8.000pt;
margin-bottom: 0.000pt;
word-spacing: 0.250em;
font-family: "Times New Roman";
font-style: normal;
font-weight: normal;
font-size: 11.0pt;
color: #000000;
letter-spacing: 0.00em;
text-decoration: none;
p.BodyLevel2 {
margin-left: 36.000pt;
text-align: left;
font-style: normal;
font-size: 11.0pt;
color: #000000;
p.BodyLevel3 {
margin-left: 54.000pt;
text-align: left;
font-style: normal;
font-size: 11.0pt;
color: #000000;
h1 {
margin-left: 0.000pt;
text-align: left;
margin-top: 17.000pt;
font-family: Arial;
font-style: normal;
font-weight: bold;
font-size: 14.0pt;
color: #000000;
h2 {
margin-right: 36.000pt;
text-align: left;
margin-top: 16.000pt;
font-family: Arial;
font-style: normal;
font-weight: bold;
font-size: 13.0pt;
color: #000000;
h3 {
text-align: left;
margin-top: 14.000pt;
font-family: Arial;
font-style: normal;
font-weight: bold;
font-size: 12.0pt;
color: #000000;
h4 {
text-align: left;
margin-top: 13.000pt;
font-family: Arial;
font-style: normal;
font-weight: bold;
font-size: 11.0pt;
color: #000000;
p.Title {
text-align: left;
margin-top: 22.000pt;
margin-bottom: 11.000pt;
font-family: Arial;
font-style: normal;
font-weight: bold;
font-size: 18.0pt;
color: #000000;
p.AuthorBook {
text-align: left;
margin-top: 0.000pt;
margin-bottom: 292.000pt;
font-family: Arial;
font-style: normal;
font-weight: bold;
font-size: 13.0pt;
color: #000000;
p.CellBody {
text-align: left;
margin-bottom: 4.000pt;
font-style: normal;
font-size: 9.0pt;
color: #000000;
p.CellHeading {
text-align: left;
font-style: normal;
font-weight: bold;
font-size: 9.0pt;
color: #000000;
p.Extract {
margin-right: 18.000pt;
text-align: left;
margin-top: 7.000pt;
font-style: normal;
font-size: 9.0pt;
color: #000000;
p.Footnote {
margin-left: 12.000pt;
text-align: left;
text-indent: -12.000pt;
margin-top: 3.000pt;
font-style: normal;
font-size: 9.0pt;
color: #000000;
p.PublisherBook {
text-align: left;
font-style: normal;
font-weight: bold;
font-size: 12.0pt;
color: #000000;
p.TitleBook {
text-align: left;
margin-bottom: 60.000pt;
font-style: italic;
font-size: 30.0pt;
color: #000000;
letter-spacing: -0.04em;
h5 {
font-weight: bold;
font-size: 10.0pt;
h6 {
font-weight: bold;
font-size: 8.0pt;
span.PageNumber {
font-weight: bold;
span.EquationVariables {
font-style: italic;
span.Emphasis {
font-style: italic;
span.Callout {
font-family: Arial;
font-style: normal;
font-size: 8.0pt;
color: #000000;
span.BulletSymbol {
font-family: Courier;
font-style: normal;
font-weight: bold;
font-size: 11.0pt;
color: #000000;
span.FirstLetterTitle {
font-style: italic;
font-size: 42.0pt;
color: #000000;
span.EquationNumber {
font-family: Arial;
font-style: normal;
font-weight: bold;
font-size: 8.0pt;
color: #000000;
span.ChapterNumber {
font-family: Arial;
font-style: normal;
font-weight: bold;
font-size: 10.0pt;
color: #000000;
letter-spacing: 0.04em;
span.StepNumber {
font-family: Arial;
font-style: normal;
font-weight: bold;
font-size: 8.0pt;
color: #000000;
span.WebJump {
span.Superscript {
font-style: normal;
color: #000000;
span.Underline {
font-style: normal;
color: #000000;
span.Bold {
font-style: normal;
font-weight: bold;
color: #000000;
span.BlueBold {
font-weight: bold;
color: #2e97dc;
span.White {
color: #ffffff;
span.Emphasis {
font-style: italic;
span.Symbol {
font-family: Symbol;
font-style: normal;
font-size: 10.0pt;
color: #000000;
span.GreyBold {
font-family: Arial;
font-weight: bold;
color: #3f3f3f;
span.Subscript {
font-style: normal;
color: #000000;
table.CellBorder {
padding: 0px;
border-top: Solid 1px #000000;
border-left: Solid 1px #000000;
x-border-spacing: 0px;
table.CellBorder td {
border-right: Solid 1px #000000;
border-bottom: Solid 1px #000000;
table.Colorful1 {
padding: 0px;
border-left-style: Solid;
border-left-width: 1px;
border-left-color: #000000;
border-top-style: Solid;
border-top-width: 1px;
border-top-color: #000000;
x-1st-row: 1;
x-1st-row-name: row1;
x-1st-col: 1;
x-1st-col-name: col1;
table.Colorful1 tr.row1 td {
background-color: #800000;
padding-right: 10px;
padding-left: 10px;
font-weight: bold;
border-right-style: Solid;
border-right-width: 1px;
border-right-color: #000000;
border-bottom-style: Solid;
border-bottom-width: 1px;
border-bottom-color: #000000;
color: #ffffff;
table.Colorful1 td.col1 {
background-color: #c0c0c0;
padding-left: 10px;
font-weight: bold;
table.Colorful1 td {
padding-left: 10px;
table.Colorful2 {
padding: 0px;
x-1st-row: 1;
x-1st-col: 1;
table.Colorful2 tr.row1 td {
background-color: #000080;
padding-left: 10px;
font-weight: bold;
color: #ffffff;
table.Colorful2 td.col1 {
background-color: #0000ff;
font-weight: bold;
padding-left: 10px;
color: #ffffff;
table.Colorful2 td {
padding-left: 10px;
table.Colorful3 {
padding: 0px;
border-left-color: #ffffff;
border-top-color: #ffffff;
x-1st-row: 1;
table.Colorful3 tr.row1 td {
padding-left: 10px;
font-weight: bold;
color: #ffffff;
table.Colorful3 td {
border-right-color: #ffffff;
border-bottom-color: #ffffff;
padding-left: 10px;
table.Colorful4 {
padding: 0px;
x-1st-row: 1;
x-1st-col: 1;
table.Colorful4 tr.row1 td {
background-color: #008000;
padding-left: 10px;
font-weight: bold;
color: #ffffff;
table.Colorful4 td.col1 {
background-color: #ffff00;
font-weight: bold;
padding-left: 10px;
table.Colorful4 td {
padding-left: 10px;
table.LastColumn {
x-row-pat-1: 1;
x-row-pat-1-name: t1Row;
x-row-pat-count: 2;
x-row-pat-2: 1;
x-row-pat-2-name: t2Row;
x-last-col: 1;
x-last-col-name: last;
text-align: Right;
font-size: 10pt;
table.LastColumn tr.t1Row td {
font-family: Arial;
font-size: 10pt;
table.LastColumn tr.t2Row td {
font-family: Arial;
font-size: 10pt;
table.LastColumn td.last {
font-family: Arial;
text-align: Right;
font-size: 10pt;
table.lastcolumn tr.t1row td.last {
font-family: Arial;
text-align: Right;
font-size: 10pt;
table.lastcolumn tr.t2row td.last {
font-family: Arial;
text-align: Right;
font-size: 10pt;
table.LastRow {
padding: 0px;
x-last-row: 1;
x-last-row-name: last;
text-align: Right;
font-family: Arial;
font-size: 10pt;
table.LastRow td {
font-family: Arial;
font-size: 10pt;
table.LastRow tr.last td {
text-align: Right;
font-family: Arial;
font-size: 10pt;
table.BottomRowRightColumn {
padding: 0px;
x-last-row: 1;
text-align: Right;
font-family: Arial;
x-row-pat-1: 1;
x-row-pat-count: 2;
x-row-pat-2: 1;
x-last-col: 1;
table.BottomRowRightColumn td {
table.BottomRowRightColumn tr.last td {
text-align: Right;
font-family: Arial;
font-size: 10pt;
table.BottomRowRightColumn tr.t1Row td {
text-align: Right;
font-family: Arial;
font-size: 10pt;
table.BottomRowRightColumn tr.t2Row td {
font-family: Arial;
font-size: 10pt;
table.BottomRowRightColumn td.last {
text-align: Right;
font-family: Arial;
font-size: 10pt;
table.BottomRowRightColumn tr.t1row td.last {
text-align: Right;
font-family: Arial;
font-size: 10pt;
table.BottomRowRightColumn tr.t2row td.last {
text-align: Right;
font-family: Arial;
font-size: 10pt;
table.LeftColumn {
x-row-pat-1: 1;
x-row-pat-count: 2;
x-row-pat-2: 1;
x-1st-col: 1;
x-1st-col-name: t1st;
table.LeftColumn tr.t1Row td {
font-family: Arial;
font-size: 10pt;
table.LeftColumn tr.t2Row td {
font-family: Arial;
font-size: 10pt;
table.LeftColumn td.t1st {
background-color: #cccccc;
font-family: Arial;
font-size: 10pt;
font-weight: bold;
table.leftcolumn tr.t1row td.t1st {
font-family: Arial;
font-size: 10pt;
font-weight: bold;
table.leftcolumn tr.t2row td.t1st {
font-family: Arial;
font-size: 10pt;
font-weight: bold;
table.LeftColumnAlternatingColumns {
x-row-pat-1: 1;
x-row-pat-count: 2;
x-row-pat-2: 1;
x-1st-col: 1;
x-col-pat-1: 1;
x-col-pat-1-name: t1Col;
x-col-pat-count: 2;
x-col-pat-2: 1;
x-col-pat-2-name: t2Col;
table.LeftColumnAlternatingColumns tr.t1Row td {
font-family: Arial;
font-size: 10pt;
table.LeftColumnAlternatingColumns tr.t2Row td {
font-family: Arial;
font-size: 10pt;
table.LeftColumnAlternatingColumns td.t1st {
font-family: Arial;
font-size: 10pt;
font-weight: bold;
table.leftcolumnalternatingcolumns tr.t1row td.t1st {
font-family: Arial;
font-size: 10pt;
font-weight: bold;
table.leftcolumnalternatingcolumns tr.t2row td.t1st {
font-family: Arial;
font-size: 10pt;
font-weight: bold;
table.LeftColumnAlternatingColumns td.t1Col {
background-color: #ccffcc;
font-family: Arial;
font-size: 10pt;
table.LeftColumnAlternatingColumns td.t2Col {
table.LeftColumnRepeatingColumns {
x-row-pat-1: 1;
x-row-pat-count: 2;
x-row-pat-2: 1;
x-1st-col: 1;
x-col-pat-1: 1;
x-col-pat-2: 1;
x-col-pat-count: 3;
x-col-pat-3: 1;
x-col-pat-3-name: t3Col;
table.LeftColumnRepeatingColumns tr.t1Row td {
font-family: Arial;
font-size: 10pt;
table.LeftColumnRepeatingColumns tr.t2Row td {
font-family: Arial;
font-size: 10pt;
table.LeftColumnRepeatingColumns td.t1st {
background-color: #808080;
font-family: Arial;
font-size: 10pt;
font-weight: bold;
table.leftcolumnrepeatingcolumns tr.t1row td.t1st {
font-family: Arial;
font-size: 10pt;
font-weight: bold;
table.leftcolumnrepeatingcolumns tr.t2row td.t1st {
font-family: Arial;
font-size: 10pt;
font-weight: bold;
table.LeftColumnRepeatingColumns td.t1Col {
font-family: Arial;
font-size: 10pt;
table.LeftColumnRepeatingColumns td.t2Col {
font-family: Arial;
font-size: 10pt;
table.LeftColumnRepeatingColumns td.t3Col {
font-family: Arial;
font-size: 10pt;
table.Line1 {
padding: 0px;
border-bottom-width: 3px;
border-bottom-color: #008000;
border-top-width: 3px;
border-top-color: #008000;
x-1st-row: 1;
table.Line1 tr.row1 td {
table.PaddedCells {
x-row-pat-1: 1;
x-row-pat-count: 2;
x-row-pat-2: 1;
x-border-spacing: 2px;
table.PaddedCells tr.t1Row td {
font-family: Arial;
font-size: 10pt;
table.PaddedCells tr.t2Row td {
font-family: Arial;
font-size: 10pt;
table.PaddedCells td {
padding-left: 5px;
padding-right: 5px;
padding-top: 5px;
padding-bottom: 5px;
table.Retro7 {
x-border-spacing: 15px;
x-row-pat-count: 1;
x-row-pat-1: 1;
table.Retro7 tr.t1Row td {
border-top-style: Groove;
border-bottom-style: Groove;
border-top-color: #00ff00;
border-top-width: 4px;
border-bottom-color: #00ff00;
border-bottom-width: 4px;
table.Retro7 td {
padding-left: 10px;
padding-top: 0px;
padding-bottom: 0px;
table.ShadedAlternatingColumns {
x-row-pat-1: 1;
x-row-pat-count: 2;
x-row-pat-2: 1;
x-col-pat-1: 1;
x-col-pat-count: 2;
x-col-pat-2: 1;
table.ShadedAlternatingColumns tr.t1Row td {
font-family: Arial;
font-size: 10pt;
table.ShadedAlternatingColumns tr.t2Row td {
font-family: Arial;
font-size: 10pt;
table.ShadedAlternatingColumns td.t1Col {
font-family: Arial;
font-size: 10pt;
table.ShadedAlternatingColumns td.t2Col {
font-family: Arial;
font-size: 10pt;
table.ShadedAlternatingRows {
x-row-pat-1: 1;
x-row-pat-count: 2;
x-row-pat-2: 1;
table.ShadedAlternatingRows tr.t1Row td {
font-family: Arial;
font-size: 10pt;
table.ShadedAlternatingRows tr.t2Row td {
font-family: Arial;
font-size: 10pt;
table.SimpleBorder {
padding: 0px;
table.SimpleBorder td {
table.TopRow {
x-1st-row: 1;
x-1st-row-name: t1st;
x-row-pat-1: 1;
x-row-pat-count: 2;
x-row-pat-2: 1;
table.TopRow tr.t1st td {
font-family: Arial;
font-size: 10pt;
font-weight: bold;
text-align: Center;
table.TopRow tr.t1Row td {
font-family: Arial;
font-size: 10pt;
table.TopRow tr.t2Row td {
font-family: Arial;
font-size: 10pt;
table.TopRowRepeatingRows {
x-row-pat-1: 1;
x-row-pat-2: 1;
x-1st-row: 1;
x-row-pat-count: 3;
x-row-pat-3: 1;
x-row-pat-3-name: t3Row;
table.TopRowRepeatingRows tr.t1Row td {
font-family: Arial;
font-size: 10pt;
table.TopRowRepeatingRows tr.t2Row td {
font-family: Arial;
font-size: 10pt;
table.TopRowRepeatingRows tr.t1st td {
font-family: Arial;
font-size: 10pt;
font-weight: bold;
text-align: Center;
table.TopRowRepeatingRows tr.t3Row td {
font-family: Arial;
font-size: 10pt;
table.TopRowAlternatingRows {
x-row-pat-1: 1;
x-row-pat-count: 2;
x-row-pat-2: 1;
x-1st-row: 1;
table.TopRowAlternatingRows tr.t1Row td {
font-family: Arial;
font-size: 10pt;
table.TopRowAlternatingRows tr.t2Row td {
font-family: Arial;
font-size: 10pt;
table.TopRowAlternatingRows tr.t1st td {
text-align: Center;
font-family: Arial;
font-size: 10pt;
font-weight: bold;
table.TopRowLeftColumn {
x-row-pat-1: 1;
x-row-pat-count: 2;
x-row-pat-2: 1;
x-1st-row: 1;
x-1st-col: 1;
table.TopRowLeftColumn tr.t1Row td {
font-family: Arial;
font-size: 10pt;
table.TopRowLeftColumn tr.t2Row td {
font-family: Arial;
font-size: 10pt;
table.TopRowLeftColumn tr.t1st td {
font-family: Arial;
font-size: 10pt;
font-weight: bold;
text-align: Center;
table.TopRowLeftColumn td.t1st {
text-align: Center;
font-family: Arial;
font-size: 10pt;
font-weight: bold;
table.toprowleftcolumn tr.t1row td.t1st {
text-align: Center;
font-family: Arial;
font-size: 10pt;
font-weight: bold;
table.toprowleftcolumn tr.t2row td.t1st {
text-align: Center;
font-family: Arial;
font-size: 10pt;
font-weight: bold;
span.WD_button {
p.WD_step1 {
color: #000000;
And here's the second:
RH_conversion_-_AMHS.css
/* Style Sheet created by ImportDoc 13.0 */
p.WD_Normal {
margin-top:0in;
margin-right:0in;
margin-bottom:8.0pt;
margin-left:0in;
line-height:107%;
font-size:11.0pt;
font-family:"Calibri"   ,sans-serif;
color:windowtext;
letter-spacing:0pt;
p.WD_Heading1 {
margin-top:0in;
margin-right:-.75in;
margin-left:22.5pt;
text-indent:-.3in;
background:#B1C2D7;
border:none;
padding:0in;
font-size:18.0pt;
font-family:"Lucida Sans Unicode"   ,sans-serif;
font-variant:small-caps;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_Heading2 {
margin-top:8.0pt;
margin-right:0in;
margin-bottom:0in;
margin-left:.5in;
margin-bottom:.0001pt;
text-indent:-.5in;
font-size:16.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_Heading3 {
margin-top:8.0pt;
margin-right:0in;
margin-bottom:0in;
margin-left:.7in;
text-indent:-.7in;
font-size:12.0pt;
color:windowtext;
letter-spacing:.1pt;
font-weight:bold;
p.WD_Heading4 {
margin-top:12.0pt;
margin-right:0in;
margin-bottom:12.0pt;
margin-left:.75in;
text-indent:-.75in;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_Heading5 {
margin-top:8.0pt;
margin-right:0in;
margin-left:.7in;
text-indent:-.7in;
font-size:12.0pt;
font-family:"Arial"   ,sans-serif;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_Heading6 {
margin-top:12.0pt;
margin-right:0in;
margin-bottom:3.0pt;
margin-left:1.0in;
text-indent:-1.0in;
font-size:10.0pt;
font-family:"Verdana"   ,sans-serif;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_Heading7 {
margin-top:12.0pt;
margin-right:0in;
margin-left:.9in;
text-indent:-.9in;
font-size:12.0pt;
font-family:"Times New Roman"   ,serif;
color:windowtext;
p.WD_Heading8 {
margin-top:12.0pt;
margin-right:0in;
margin-left:1.0in;
text-indent:-1.0in;
font-size:12.0pt;
color:windowtext;
font-style:italic;
p.WD_Heading9 {
margin-top:12.0pt;
margin-right:0in;
margin-left:1.1in;
text-indent:-1.1in;
font-size:11.0pt;
color:windowtext;
p.WD_Index1 {
margin-top:12.0pt;
margin-right:0in;
margin-left:.5in;
text-indent:-.5in;
font-size:10.0pt;
color:windowtext;
p.WD_Index2 {
margin-top:12.0pt;
margin-right:0in;
margin-left:.75in;
text-indent:-.5in;
font-size:10.0pt;
color:windowtext;
p.WD_Index3 {
margin-top:12.0pt;
margin-right:0in;
margin-left:1.0in;
text-indent:-.5in;
font-size:10.0pt;
color:windowtext;
p.WD_Index4 {
margin-top:12.0pt;
margin-right:0in;
margin-left:1.25in;
text-indent:-.5in;
font-size:10.0pt;
color:windowtext;
p.WD_Index5 {
margin-top:12.0pt;
margin-right:0in;
margin-left:1.5in;
text-indent:-.5in;
font-size:10.0pt;
color:windowtext;
p.WD_Index6 {
margin-top:12.0pt;
margin-right:0in;
margin-left:1.25in;
text-indent:-.5in;
font-size:10.0pt;
color:windowtext;
p.WD_Index7 {
margin-top:12.0pt;
margin-right:0in;
margin-left:1.5in;
text-indent:-.5in;
font-size:10.0pt;
color:windowtext;
p.WD_Index8 {
margin-top:12.0pt;
margin-right:0in;
margin-left:1.75in;
text-indent:-.5in;
font-size:10.0pt;
color:windowtext;
p.WD_Index9 {
margin-top:12.0pt;
margin-right:0in;
margin-left:2.0in;
text-indent:-.5in;
font-size:10.0pt;
color:windowtext;
p.WD_Toc1 {
margin-top:6.0pt;
margin-right:0in;
margin-bottom:2.0pt;
margin-left:45.35pt;
text-indent:-45.35pt;
font-size:14.0pt;
font-family:"Times New Roman Bold"   ,serif;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_Toc2 {
margin-top:0in;
margin-right:0in;
margin-bottom:0in;
margin-left:66.6pt;
text-indent:-30.6pt;
font-size:11.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_Toc3 {
margin-top:0in;
margin-right:0in;
margin-bottom:0in;
margin-left:81.0pt;
text-indent:-45.0pt;
font-size:9.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_Toc4 {
margin-top:0in;
margin-right:0in;
margin-bottom:0in;
margin-left:1.25in;
text-indent:-.75in;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_Toc5 {
margin-top:0in;
margin-right:0in;
margin-bottom:0in;
margin-left:.5in;
font-size:10.0pt;
color:windowtext;
p.WD_Toc6 {
margin-top:1.0pt;
margin-right:0in;
margin-bottom:1.0pt;
margin-left:117.35pt;
text-indent:-63.35pt;
font-size:9.0pt;
font-family:"Georgia"   ,serif;
color:windowtext;
letter-spacing:0pt;
p.WD_Toc7 {
margin-top:0in;
margin-right:0in;
margin-bottom:0in;
margin-left:1.0in;
font-size:10.0pt;
color:windowtext;
p.WD_Toc8 {
margin-top:0in;
margin-right:0in;
margin-bottom:0in;
margin-left:84.0pt;
font-size:10.0pt;
color:windowtext;
p.WD_Toc9 {
margin-top:0in;
margin-right:0in;
margin-bottom:0in;
margin-left:96.0pt;
font-size:10.0pt;
color:windowtext;
p.WD_NormalIndent {
margin-top:12.0pt;
margin-right:0in;
margin-left:.5in;
font-size:10.0pt;
color:windowtext;
p.WD_FootnoteText {
margin-top:12.0pt;
margin-right:0in;
margin-left:9.35pt;
text-indent:-9.35pt;
line-height:11.0pt;
font-size:9.0pt;
color:windowtext;
p.WD_CommentText {
margin-top:12.0pt;
margin-right:0in;
margin-left:9.35pt;
line-height:11.0pt;
font-size:10.0pt;
color:windowtext;
p.WD_Header {
margin:0in;
border:none;
padding:0in;
font-size:10.0pt;
font-family:"Eras Light ITC"   ,sans-serif;
color:windowtext;
p.WD_Footer {
margin:0in;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
p.WD_IndexHeading {
margin-top:6.0pt;
margin-right:0in;
margin-left:0in;
font-size:14.0pt;
color:windowtext;
font-weight:bold;
p.WD_CaptionTableTitle {
margin-top:3.0pt;
margin-right:0in;
margin-bottom:0in;
margin-left:0in;
text-align:center;
font-size:11.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_Tof {
margin-top:1.0pt;
margin-right:0in;
font-size:9.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_EnvelopeAddress {
margin-top:12.0pt;
margin-right:0in;
margin-left:2.0in;
font-size:10.0pt;
color:windowtext;
p.WD_EnvelopeReturn {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
span.WD_FootnoteReference {
vertical-align:super;
span.WD_CommentReference {
color:navy;
display:none;
span.WD_LineNumber {
span.WD_PageNumber {
font-weight:bold;
span.WD_EndnoteReference {
p.WD_EndnoteText {
margin-top:12.0pt;
margin-right:0in;
margin-left:9.35pt;
line-height:11.0pt;
font-size:9.0pt;
color:windowtext;
p.WD_Toa {
margin-top:12.0pt;
margin-right:0in;
margin-left:.25in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
p.WD_MacroText {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-family:Courier New;
color:windowtext;
font-weight:bold;
p.WD_ToaHeading {
margin-top:6.0pt;
margin-right:0in;
margin-left:0in;
font-size:14.0pt;
color:windowtext;
letter-spacing:1.0pt;
font-weight:bold;
p.WD_List {
margin-top:2.0pt;
margin-right:0in;
margin-left:.75in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListBullet {
margin-top:2.0pt;
margin-right:0in;
margin-left:.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListNumber {
margin-top:2.0pt;
margin-right:0in;
margin-left:.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_List2 {
margin-top:2.0pt;
margin-right:0in;
margin-left:.75in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_List3 {
margin-top:2.0pt;
margin-right:0in;
margin-left:1.0in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_List4 {
margin-top:2.0pt;
margin-right:0in;
margin-left:1.25in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_List5 {
margin-top:2.0pt;
margin-right:0in;
margin-left:1.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListBullet2 {
margin-top:2.0pt;
margin-right:0in;
margin-left:.75in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListBullet3 {
margin-top:2.0pt;
margin-right:0in;
margin-left:1.0in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListBullet4 {
margin-top:2.0pt;
margin-right:0in;
margin-left:1.25in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListBullet5 {
margin-top:2.0pt;
margin-right:0in;
margin-left:1.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListNumber2 {
margin-top:2.0pt;
margin-right:0in;
margin-left:.75in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListNumber3 {
margin-top:2.0pt;
margin-right:0in;
margin-left:1.0in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListNumber4 {
margin-top:2.0pt;
margin-right:0in;
margin-left:1.25in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListNumber5 {
margin-top:2.0pt;
margin-right:0in;
margin-left:1.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_Title {
margin-top:0in;
margin-right:0in;
margin-bottom:15.0pt;
margin-left:0in;
border:none;
padding:0in;
font-size:26.0pt;
font-family:"Calibri Light"   ,sans-serif;
color:#323E4F;
letter-spacing:.25pt;
p.WD_TitleCxSpFirst {
margin:0in;
border:none;
padding:0in;
font-size:26.0pt;
color:#323E4F;
p.WD_TitleCxSpMiddle {
margin:0in;
border:none;
padding:0in;
font-size:26.0pt;
color:#323E4F;
p.WD_TitleCxSpLast {
margin-top:0in;
margin-right:0in;
margin-left:0in;
border:none;
padding:0in;
font-size:26.0pt;
color:#323E4F;
p.WD_Closing {
margin-top:12.0pt;
margin-right:0in;
margin-left:3.0in;
font-size:10.0pt;
color:windowtext;
p.WD_Signature {
margin-top:12.0pt;
margin-right:0in;
margin-left:3.0in;
font-size:10.0pt;
color:windowtext;
p.WD_BodyTextBodyTextChar2BodyTextCharChar1BodyTextChar1CharCharBodyTextCharCharCharCharBodyTextChar1CharCharCharCharBodyTextCharCharCharCharCharCharBodyTextChar2CharCharCharCharCharBodyTextChar1Char1Char {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_BodyTextIndent {
margin-top:12.0pt;
margin-right:0in;
margin-bottom:6.0pt;
margin-left:.25in;
font-size:10.0pt;
color:windowtext;
p.WD_ListContinue {
margin-top:2.0pt;
margin-right:0in;
margin-left:.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListContinue2 {
margin-top:2.0pt;
margin-right:0in;
margin-left:.75in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListContinue3 {
margin-top:2.0pt;
margin-right:0in;
margin-left:1.0in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListContinue4 {
margin-top:2.0pt;
margin-right:0in;
margin-left:1.25in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListContinue5 {
margin-top:2.0pt;
margin-right:0in;
margin-left:1.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_MessageHeader {
margin-top:12.0pt;
margin-right:2.0in;
margin-left:.75in;
text-indent:-.75in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_Subtitle {
margin-top:0in;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:14.0pt;
color:windowtext;
font-style:italic;
p.WD_Salutation {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
p.WD_Date {
margin-top:24.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:10.0pt;
color:windowtext;
p.WD_BodyTextFirstIndent {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
text-indent:10.5pt;
font-size:10.0pt;
color:windowtext;
p.WD_BodyTextFirstIndent2 {
margin-top:12.0pt;
margin-right:0in;
margin-left:.25in;
text-indent:10.5pt;
font-size:10.0pt;
color:windowtext;
p.WD_NoteHeading {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
p.WD_BodyText2 {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
p.WD_BodyText3 {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
p.WD_BodyTextIndent2 {
margin-top:12.0pt;
margin-right:0in;
margin-left:.25in;
font-size:10.0pt;
color:windowtext;
p.WD_BodyTextIndent3 {
margin-top:12.0pt;
margin-right:0in;
margin-left:.25in;
font-size:10.0pt;
color:windowtext;
p.WD_BlockText {
margin-top:12.0pt;
margin-right:1.0in;
margin-left:1.0in;
font-size:10.0pt;
color:windowtext;
span.WD_Hyperlink {
color:blue;
font-style:italic;
text-decoration:underline;
text-underline:single;
span.WD_HyperlinkFollowed {
color:purple;
p.WD_DocumentMap {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
background:navy;
font-size:10.0pt;
font-family:"Tahoma"   ,sans-serif;
color:windowtext;
p.WD_PlainText {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
p.WD_AutoSig {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
p.WD_CommentSubject {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_Acetate {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
span.WD_PlaceholderText {
color:gray;
p.WD_NoSpacing {
margin:0in;
font-size:8.0pt;
color:windowtext;
p.WD_RMPane {
margin:0in;
font-size:8.0pt;
color:windowtext;
p.WD_ListParagraph {
margin-top:12.0pt;
margin-right:0in;
margin-left:.5in;
font-size:10.0pt;
color:windowtext;
p.WD_ListParagraphCxSpFirst {
margin-top:12.0pt;
margin-right:0in;
margin-bottom:0in;
margin-left:.5in;
font-size:10.0pt;
color:windowtext;
p.WD_ListParagraphCxSpMiddle {
margin-top:0in;
margin-right:0in;
margin-bottom:0in;
margin-left:.5in;
font-size:10.0pt;
color:windowtext;
p.WD_ListParagraphCxSpLast {
margin-top:0in;
margin-right:0in;
margin-left:.5in;
font-size:10.0pt;
color:windowtext;
span.WD_Heading1 {
background:#B1C2D7;
font-weight:bold;
span.WD_Heading2 {
font-weight:bold;
span.WD_Heading3 {
font-weight:bold;
span.WD_Heading4 {
font-weight:bold;
span.WD_Heading5 {
font-weight:bold;
span.WD_Heading6 {
font-weight:bold;
span.WD_Heading7 {
span.WD_Heading8 {
font-style:italic;
span.WD_Heading9 {
p.WD_IMPORTANT {
margin-top:6.0pt;
margin-right:1.0in;
margin-left:84.95pt;
text-indent:-1.05in;
background:#FFFF99;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_normalcell {
margin-top:2.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
p.WD_Step1 {
margin-top:4.0pt;
margin-right:0in;
margin-bottom:4.0pt;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
margin-top:8.0pt;
margin-right:0in;
margin-left:99.05pt;
text-indent:-18.45pt;
font-size:8.0pt;
font-family:"Arial Narrow"   ,sans-serif;
color:windowtext;
letter-spacing:0pt;
margin-top:12.0pt;
margin-right:0in;
margin-left:.25in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
span.WD_button {
border:solid #7B7B7B 1.0pt;
padding:0in;
font-weight:bold;
span.WD_italics {
font-style:italic;
p.WD_CellLverdana9 {
margin-top:1.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
p.WD_Cell1R {
margin-top:1.0pt;
margin-right:0in;
margin-left:0in;
text-align:right;
font-size:10.0pt;
color:windowtext;
p.WD_Cell1L {
margin-top:1.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
span.WD_selectoption {
padding:0in;
font-weight:bold;
span.WD_paragraphnote {
position:relative;
top:0pt;
letter-spacing:0pt;
span.WD_bold {
font-weight:bold;
font-weight:bold;
p.WD_NOTE {
margin-top:12.0pt;
margin-right:2.25pt;
margin-left:5.4pt;
background:#E0E0E0;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
p.WD_TableHeadingC {
margin:0in;
text-align:center;
font-size:8.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_Captioncont {
margin-top:3.0pt;
margin-right:0in;
margin-bottom:0in;
margin-left:0in;
text-align:center;
font-size:8.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_tablecaptioncont {
margin-top:1.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_Normalnoindent {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_callout800 {
margin:0in;
font-size:8.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_NOTEQRG {
margin:0in;
line-height:9.0pt;
background:#E0E0E0;
border:none;
padding:0in;
font-size:9.0pt;
font-family:"Franklin Gothic Book"   ,sans-serif;
color:windowtext;
letter-spacing:0pt;
p.WD_IMPORTANTQRG {
margin-top:0in;
margin-right:0in;
margin-bottom:0in;
margin-left:16.55pt;
text-indent:-15.1pt;
line-height:9.0pt;
background:#FFFF99;
border:none;
padding:0in;
font-size:9.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_sectionQRG {
margin:0in;
line-height:12.0pt;
font-size:12.0pt;
font-family:"Segoe UI"   ,sans-serif;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_CAUTION {
margin-top:6.0pt;
margin-right:1.0in;
background:#FFFF99;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_stepacell {
margin-top:0in;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
span.WD_StylefilefolderpathBookmanOldStyle {
font-family:"Bookman Old Style"   ,serif;
position:relative;
top:0pt;
letter-spacing:0pt;
font-weight:bold;
span.WD_filefolderpath {
position:relative;
top:0pt;
letter-spacing:0pt;
font-weight:bold;
span.WD_linkclick {
color:#282850;
font-weight:bold;
span.WD_link {
color:#282850;
font-weight:bold;
p.WD_callout {
margin:0in;
text-align:center;
text-autospace:none;
font-size:9.0pt;
color:black;
letter-spacing:0pt;
p.WD_callout8c {
margin:0in;
text-align:center;
font-size:9.0pt;
color:windowtext;
letter-spacing:0pt;
span.WD_notepara {
font-family:"Cambria"   ,serif;
position:relative;
top:0pt;
letter-spacing:0pt;
font-style:italic;
text-decoration:none;
text-underline:none;
span.WD_HTMLAddress {
font-style:italic;
span.WD_HTMLPreformatted {
span.WD_CommentText {
span.WD_Header {
span.WD_Footer {
span.WD_EndnoteText {
span.WD_MacroText {
font-weight:bold;
span.WD_Closing {
span.WD_Signature {
span.WD_BodyTextIndent {
span.WD_MessageHeader {
font-weight:bold;
span.WD_Title {
color:#323E4F;
span.WD_Subtitle {
font-style:italic;
span.WD_Salutation {
span.WD_Date {
span.WD_BodyTextFirstIndent {
span.WD_BodyTextChar1BodyTextChar2Char1BodyTextCharChar1Char1BodyTextChar1CharCharChar1BodyTextCharCharCharCharChar1BodyTextChar1CharCharCharCharChar1BodyTextCharCharCharCharCharCharChar1 {
font-weight:bold;
span.WD_BodyTextFirstIndent2 {
span.WD_NoteHeading {
span.WD_BodyText2 {
span.WD_BodyText3 {
span.WD_BodyTextIndent2 {
span.WD_BodyTextIndent3 {
span.WD_DocumentMap {
background:navy;
span.WD_PlainText {
span.WD_EmailSignature {
span.WD_CommentSubject {
font-weight:bold;
span.WD_BalloonText {
p.WD_footnote {
margin-top:6.0pt;
margin-right:0in;
margin-left:9.35pt;
font-size:10.0pt;
color:windowtext;
p.WD_BlockQuotation {
margin-top:12.0pt;
margin-right:.5in;
margin-left:.5in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
font-style:italic;
p.WD_BlockQuotationFirst {
margin-top:6.0pt;
margin-right:.5in;
margin-left:.5in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
font-style:italic;
p.WD_BlockQuotationLast {
margin-top:12.0pt;
margin-right:.5in;
margin-left:.5in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
font-style:italic;
p.WD_Body1L {
margin-top:6.0pt;
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_Body1R {
margin-top:6.0pt;
margin-right:0in;
margin-left:0in;
text-align:right;
font-size:12.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_callout10V {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_Cell {
margin-top:2.0pt;
margin-right:0in;
margin-bottom:0in;
margin-left:.2in;
text-indent:-.2in;
font-size:10.0pt;
color:windowtext;
p.WD_Cella {
margin-top:2.0pt;
margin-right:0in;
margin-bottom:0in;
margin-left:.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
span.WD_Cell1R {
p.WD_ChapterLabel {
margin-top:.25in;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ChapterSubtitle {
margin-top:.25in;
margin-right:0in;
margin-bottom:.25in;
margin-left:0in;
text-align:center;
font-size:14.0pt;
color:windowtext;
font-style:italic;
p.WD_ChapterTitle {
margin-top:30.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:16.0pt;
color:windowtext;
font-weight:bold;
p.WD_GlossaryDefinition {
margin-top:12.0pt;
margin-right:0in;
margin-left:.25in;
layout-grid-mode:char;
font-size:10.0pt;
color:windowtext;
p.WD_DocumentLabel {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:18.0pt;
color:windowtext;
font-weight:bold;
p.WD_Figure {
margin:0in;
text-align:center;
border:none;
padding:0in;
font-size:12.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_FigureLabel {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
span.WD_figureAncorC {
p.WD_figureAncorC {
margin-top:0in;
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_figureAncorL {
margin-top:0in;
margin-right:0in;
margin-bottom:10.0pt;
margin-left:0in;
font-size:12.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_figureAncorR {
margin-top:0in;
margin-right:0in;
margin-left:0in;
text-align:right;
font-size:12.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_FooterEven {
margin:0in;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
p.WD_FooterFirst {
margin:0in;
text-align:center;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
p.WD_FooterOdd {
margin:0in;
text-align:right;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
p.WD_Footerpps {
margin:0in;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_FootnoteBase {
margin-top:12.0pt;
margin-right:0in;
margin-left:9.35pt;
line-height:11.0pt;
font-size:9.0pt;
color:windowtext;
p.WD_HeaderBase {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
p.WD_HeaderEven {
margin:0in;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
p.WD_HeaderFirst {
margin:0in;
text-align:center;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
p.WD_HeaderOdd {
margin:0in;
text-align:right;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
p.WD_Heading2table {
margin-top:0in;
margin-right:0in;
margin-bottom:0in;
font-size:16.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_Heading3no {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_Heading4table {
margin-top:2.0pt;
margin-right:0in;
margin-left:1.0in;
text-indent:-1.0in;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_HeadingBase {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:18.0pt;
color:windowtext;
font-weight:bold;
p.WD_Heading0 {
margin:0in;
text-align:center;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_HeadingCno {
margin-top:0in;
margin-left:0in;
text-align:center;
text-indent:0in;
background:#B1C2D7;
border:none;
padding:0in;
font-size:18.0pt;
color:windowtext;
font-weight:bold;
p.WD_HeadingCnoNoBrk {
margin-top:.25in;
margin-left:0in;
text-align:center;
text-indent:0in;
background:#B1C2D7;
border:none;
padding:0in;
font-size:18.0pt;
color:windowtext;
font-weight:bold;
p.WD_IndexBase {
margin-top:12.0pt;
margin-right:0in;
margin-left:.5in;
text-indent:-.5in;
font-size:10.0pt;
color:windowtext;
p.WD_ListBulletFirst {
margin-top:4.0pt;
margin-right:0in;
margin-left:.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListBulletLast {
margin-top:2.0pt;
margin-right:0in;
margin-left:.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListFirst {
margin-top:4.0pt;
margin-right:0in;
margin-left:.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListLast {
margin-top:2.0pt;
margin-right:0in;
margin-left:.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListNumberFirst {
margin-top:4.0pt;
margin-right:0in;
margin-left:.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ListNumberLast {
margin-top:2.0pt;
margin-right:0in;
margin-left:.5in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
span.WD_TableHeadingC {
font-weight:bold;
p.WD_TableHeadingL {
margin:0in;
text-align:center;
font-size:8.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_ListHeadingLunderline {
margin:0in;
text-align:center;
font-size:12.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_Notes {
margin-top:6.0pt;
margin-right:.25in;
margin-left:81.35pt;
background:#F3F3F3;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_num10c {
margin-top:3.0pt;
margin-right:0in;
margin-left:.25in;
text-indent:-.25in;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_PageBrk {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
line-height:1.0pt;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_PartLabel {
margin-top:30.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:12.0pt;
color:windowtext;
p.WD_PartSubtitle {
margin-top:.25in;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:16.0pt;
color:windowtext;
font-style:italic;
p.WD_PartTitle {
margin-top:30.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:18.0pt;
color:windowtext;
font-weight:bold;
p.WD_Picture {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_ReturnAddress {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:10.0pt;
font-family:"Garamond"   ,serif;
color:windowtext;
letter-spacing:-.15pt;
p.WD_SectionHeading {
margin-top:6.0pt;
margin-right:0in;
margin-left:0in;
font-size:14.0pt;
color:windowtext;
font-weight:bold;
p.WD_SectionLabel {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:18.0pt;
color:windowtext;
font-weight:bold;
p.WD_SubtitleCover {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:18.0pt;
color:windowtext;
font-style:italic;
p.WD_table {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_TableHeading2 {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:10.0pt;
color:black;
font-weight:bold;
p.WD_TableHeading2C {
margin-top:2.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_TableHeadingR {
margin-top:0in;
margin-right:2.15pt;
margin-bottom:0in;
margin-left:0in;
text-align:right;
font-size:8.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_TitleCover {
margin-top:.5in;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:24.0pt;
color:windowtext;
font-weight:bold;
p.WD_TOCBase {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
span.WD_CAUTION {
background:#FFFF99;
span.WD_CellLverdana9 {
span.WD_figureanchor {
p.WD_figureanchor {
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:8.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_head1ap {
margin-top:0in;
margin-right:0in;
margin-left:1.0in;
text-indent:-1.0in;
font-size:16.0pt;
font-family:"Eras Medium ITC"   ,sans-serif;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_head2ap {
margin-top:8.0pt;
margin-right:0in;
margin-bottom:0in;
margin-left:.4in;
text-indent:-.4in;
font-size:13.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_head3ap {
margin-top:8.0pt;
margin-right:0in;
margin-bottom:0in;
margin-left:.5in;
text-indent:-.5in;
font-size:12.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_head4ap {
margin-top:8.0pt;
margin-right:0in;
margin-bottom:0in;
margin-left:.6in;
text-indent:-.6in;
font-size:12.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_head5ap {
margin-top:0in;
margin-right:0in;
margin-bottom:0in;
margin-left:.7in;
text-indent:-.7in;
font-size:12.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_Headingno {
margin:0in;
text-align:center;
line-height:150%;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
span.WD_none {
p.WD_none {
margin:0in;
font-size:8.0pt;
color:windowtext;
span.WD_Normalnoindent {
span.WD_Step1 {
span.WD_subheaderno {
font-weight:bold;
p.WD_subheaderno {
margin-top:8.0pt;
margin-right:0in;
margin-bottom:0in;
margin-left:0in;
font-size:11.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
p.WD_Figuretitle {
margin-top:1.0pt;
margin-right:0in;
margin-left:-.35pt;
text-align:center;
border:none;
padding:0in;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
font-weight:bold;
font-style:italic;
span.WD_Stepa {
p.WD_Stepa {
margin-top:8.0pt;
margin-right:0in;
margin-left:1.0in;
text-indent:-.25in;
font-size:8.0pt;
color:windowtext;
letter-spacing:0pt;
margin-top:12.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
p.WD_tablecaption {
margin-top:1.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:8.0pt;
color:windowtext;
font-weight:bold;
font-style:italic;
p.WD_CellRverdana9 {
margin-top:1.0pt;
margin-right:0in;
margin-left:0in;
text-align:right;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_spacernormal8pt00 {
margin:0in;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
span.WD_LeadinEmphasis {
font-weight:bold;
font-style:italic;
span.WD_Superscript {
position:relative;
top:0pt;
span.WD_MyHighlight {
font-family:"Microsoft Sans Serif"   ,sans-serif;
font-weight:bold;
span.WD_AtOnInUnderthewinfoldrtabareafield {
letter-spacing:0pt;
font-style:italic;
span.WD_boldVerdana {
letter-spacing:0pt;
font-weight:bold;
span.WD_passworditalic {
position:relative;
top:0pt;
letter-spacing:.4pt;
font-style:italic;
span.WD_type {
letter-spacing:.05pt;
span.WD_optionselect {
font-weight:bold;
span.WD_Cell1L {
p.WD_Cell2L {
margin-top:1.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_Cell2C {
margin-top:1.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
p.WD_Cell1C {
margin-top:1.0pt;
margin-right:0in;
margin-left:0in;
text-align:center;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
span.WD_FootnoteText {
p.WD_GlossaryTerm {
margin-top:1.0pt;
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
color:windowtext;
font-weight:bold;
p.WD_calibri {
margin:0in;
font-size:10.0pt;
color:windowtext;
letter-spacing:0pt;
span.WD_Ins {
text-underline:double;
color:blue;
span.WD_Del {
text-decoration:line-through;
color:red;
OL {
margin-top:0px;
margin-bottom:0px;
UL {
margin-top:0px;
margin-bottom:0px;
Jan 15, 2015 Jan 15, 2015
What you have shown are heading styles and you found that problem did not occur if you did not include the TOC in the link. I believe you then said there were other instances of this problem. I would need to see images of those.
As far as the output is concerned, that is covered in Importing Using RoboHelp 9, 10 and 11 on my site. See Internal (Embedded) style sheet under Fixing the import. You are linking but there is a solution that will help. Alternatively you would have to use a find and replace operation on the output to remove the embedded style.
@petergrainge
Here it is.
Since the code references "default.css", I'm including that too:
body {
font-family: Arial;
background-color: #ffffff;
h1 {
font-weight: bold;
font-size: 24.0pt;
color: #000000;
x-next-class: ;
x-next-type: p;
LI.h1 {
font-weight: bold;
font-size: 24.0pt;
color: #0000ff;
h2 {
font-weight: bold;
font-size: 18.0pt;
LI.h2 {
font-weight: bold;
font-size: 18.0pt;
h3 {
font-weight: bold;
font-size: 14.0pt;
LI.h3 {
font-weight: bold;
font-size: 14.0pt;
h4 {
font-weight: bold;
font-size: 12.0pt;
LI.h4 {
font-weight: bold;
font-size: 12.0pt;
h5 {
font-weight: bold;
font-size: 10.0pt;
LI.h5 {
font-weight: bold;
font-size: 10.0pt;
h6 {
font-weight: bold;
font-size: 8.0pt;
LI.h6 {
font-weight: bold;
font-size: 8.0pt;
p {
font-size: 12.0pt;
margin-top: 0pt;
margin-bottom: 0pt;
LI.p {
font-size: 12.0pt;
a.expandspot {
color: #008000;
cursor: hand;
font-style: italic;
span.expandtext {
font-style: italic;
color: #ff0000;
a.dropspot {
cursor: hand;
color: #008000;
font-style: italic;
a.glossterm {
color: #800000;
cursor: hand;
font-style: italic;
span.glosstext {
font-style: italic;
color: #0000ff;
ol,
ul {
margin-top: 0px;
margin-bottom: 0px;
Jan 19, 2015 Jan 19, 2015
Can you let me have a Word document that will cause this problem?
See the Contact page on my site and send the project as instructed there. Do make sure you include a link to this thread and please do not email the document direct.
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
