I am encountering a bit of a glitch with the servers selected
for the webhelkp output.
This is the situation:
I have one project that is generated in Webhelp, webhelp pro
and pdf. This project has a few condistional biuld in order to
differenciate between two broad types of applications:
international and national.
The webhelp output is used for our desktop applications. I
therefore publish the files on the corporate network from where the
CD/DVD is pressed.
The project is therefore published to each application folder
with either the conditional build expression "National" or
"International". To do so, I created two webhelp layouts, each with
the relevant conditional build expression.
Till this point no problemo.
Next step is to specify where each webhelp layout needs to be
published. For each of these layouts, I therefore create as many
new "servers" as I need using the "File System" option. Again, no
problem, each server is created.
So all the servers are listed under each of the webhelp
layouts. There are 32 locations where the help system needs to be
copied, so there are 32 server names listed.
Now my problem is that when I activate the check-boxes
corresponding to the servers I want the layout to publish to, they
are never saved when I come back to it at future date. For example,
one of the layouts needs to be published to 20 different "servers".
When I come back to it, out of the 20 server names that I had
selected, only 10 of them are now selected. Therefore I have to
reselect them each time.
I tried modifying the SSL files and SSS file but that does
not seem to be working for me.
Does anybody now if there is a limit to the number servers
that you can allocate to a webhelp layout? If there is, is there
anyway to work around this limitation without having to manually
respecify each time?
This is especially usefull so I can batch generate the
project without have to generate and publish each individual
layout.
Many thank in advance,
Chris
