The topic above pretty much describes the situation. Numerous attempts bring the same results. It stops at this point and goes no further.
Any thoughts?
Robohelp 9
Generating WebHelp. Issue not encountered before now.
Thanks.
Holly
So what’s changed? Does it behave the same way if you try one of the sample projects? Have you tried playing with a backup copy & started tossing out half the topics at a time to see if you can isolate a problem topic?
Does the Output View window offer any clues?
Will observe the output window at the editor's desk this afternoon. Good input. Just as Jeff's was. Will post back with results tomorrow.
Thank you.
The Output window stops at the same point each time. I observed the attempt to generate and publish. It stops at Processing Full-Text Search Data and the same point on the bar indicator each time.
Generating content 'Content.' Most of the topics in her project link to pdfs stored on a network drive. She removed links to all pdfs that she had not converted from Word to pdf herself. In the past, the linked pdfs have not been problematic. She did generate and publish a test project without any trouble.
So you know then that the issue is in the project – time to start tossing topics ;>)
Hello again
Okay, I'm going to crawl out on this shaky little limb and suggest that it might have something to do with one of the PDFs.
To test this, I'd say to use Windows Explorer to simply move ALL the PDFs from the folder to a different location. Just temporarily.
See if things generate. If so, then it becomes a matter of moving them back into the project until you find the one with the issue. It could be nearly anything. The file name. Content inside the PDF. Etc.
Hopefully this helps... Rick
I haven't read back through the thread but this post is ringing a bell. See
Using RoboHelp on my site. I think it was something to do with version
compatibility in the PDF.
Late here so will look in the morning.
The issue I was thinking of was Item 22 at Using RoboHelp 8. It's not the same thing and it is not the version of RoboHelp that you are using.
With that out of the way, I would be suggesting the same as Rick.
I’m assisting an editor/author/publisher in my office who is relatively new to RoboHelp. I had hoped this was a simple fix.
I asked what changes have been made since the last time she published successfully. Most of her topics link to exterior pdfs. She said a ton.
I’ll go to her desk and try a sample project.
Thanks for the validation of what I suspected has to be done.
