org.apache.axis2.AxisFault: com.ctc.wstx.exc.WstxIOException: Attempted read on closed stream. on local .NET webservice
Jan 14, 2015 Jan 14, 2015
To facilitate code sharing between ColdFusion and our .NET applications we have a .NET webservice running through IIS on localhost.
Occasionally, under what appears to be high or persistent load, this connection errors out, which it didn't do with ColdFusion 9.  Is there something I can change on either the service or the in ColdFusion to prevent this from coming up?
Note that the service uses basicHttpBinding (<basicHttpBinding>) .  It is listening to localhost on port 8888, and is not https.
The fault returned when invoking the web service operation is:
at org.apache.axis2.AxisFault.makeFault(AxisFault.java:430)
at org.apache.axis2.transport.TransportUtils.createSOAPMessage(TransportUtils.java:124)
at org.apache.axis2.transport.TransportUtils.createSOAPMessage(TransportUtils.java:68)
at org.apache.axis2.description.OutInAxisOperationClient.handleResponse(OutInAxisOperation.java:354)
at org.apache.axis2.description.OutInAxisOperationClient.send(OutInAxisOperation.java:421)
at org.apache.axis2.description.OutInAxisOperationClient.executeImpl(OutInAxisOperation.java:229)
at org.apache.axis2.client.OperationClient.execute(OperationClient.java:165)
at org.tempuri.ErmsInternalStub.textToSpeech(ErmsInternalStub.java:828)
at sun.reflect.GeneratedMethodAccessor46.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606) at coldfusion.xml.rpc.Axis... ''
2.2K
Enthusiast ,
Jan 16, 2015 Jan 16, 2015
Seems like you have upgraded to CF 10 or CF11
Try tuning CF and jvm
HTH
VJ
Jan 19, 2015 Jan 19, 2015
I figured this out.  I was storing the CreateObject('webservice'...) result in the application scope and using it for each page call.  In CF9 this was fine, but in 10 calling from the same object concurrently caused the problems above.  Creating a new object for each request resolves the issue.
Documentation
