I'm confused. I am trying to open an InDesign file sent from an external company. I have CS6 installed. When I try and open the file I get the following error message. What is CS8.0??? I thought the versions went from CS6 straight to CC???
That's an incorrect error message based on some faulty programming. CS8 is
actually CC2014 and you'll either need that or the CC user will have to save
it back via IDML.
you just saved me a huge clump of hair.
And BTW, you cannot run CC on Windows XP.
Great, thanks for that. Makes more sense now
i am on a mac and I'm getting this message:
it was made on a 2014 version of indesign. now only have the 2015. so why is it not working?
There is no such thing as a 2015 version of InDesign. Please check the ACTUAL version you have in ABOUT, don't assume.
doc was made with CS5 trying to open with CS6
the error asked for 8.0 and this is a screen shot of indesign i am trying to open it with…
Ok, this means the file was last saved with InDesign CC2014 (which is reported as CS 8.0). It may have been started in CS6, but someone edited it in CC2014.
CC2014 is two versions newer than CS6. CS6 was released in 2011.
If you are a CC subscriber you can have both CS6 and CC2014 at the same time.
ok thanks. that was helpful
If someone gets the message in CS6 that a file was created in CS7 or CS8 or in the future any other CS version, he should update his version to the latest available CS6 update, because this error message was corrected in later updates to that program.
Hi. I just purchased the CS6 upgrade Monday, finally got it all installed this morning. I'm still getting the error message about a file being created in CS8.2? Any suggestions???
Did you read this thread? CS8 is CC 2014 (version 10). The error message should be corrected if you update CS6 to the latest patch.
You should upgrade to InDesign CC 2014 which is the mentioned CS8.
im having the same problem. Havent Adobe released compatibility plug ins for CC and CS6???
‌Do you have a CC subscription? If so your subscription CS6 has a conversion tool. Otherwise no, you always need the version it was saved from.
