I recently moved from coldfusion 8 to coldfusion 9 but all the pages with cfgrid: is throwing the following error. Any suggestion would be of great help
coldfusion.jsp.JRunTagLibraryInfo$NoSuchAttributeException: The tag handler gridcolumn does not have a setter for the attribute autoExpand specified in the Tag Library Descriptor.
at coldfusion.jsp.JRunTagLibraryInfo.getPropertyType(JRunTagLibraryInfo.java:627)
at coldfusion.jsp.JRunTagLibraryInfo.buildTagInfo(JRunTagLibraryInfo.java:585)
at coldfusion.jsp.JRunTagLibraryInfo.getTag(JRunTagLibraryInfo.java:267)
at coldfusion.compiler.NeoTranslationContext.findTagName(NeoTranslationContext.java:346)
at coldfusion.compiler.NeoTranslationContext.isKnownTag(NeoTranslationContext.java:222)
at coldfusion.compiler.CFMLParserBase.isKnownTagName(CFMLParserBase.java:589)
at coldfusion.compiler.cfml40TokenManager.TokenLexicalActions(cfml40TokenManager.java:6704)
at coldfusion.compiler.cfml40TokenManager.getNextToken(cfml40TokenManager.java:6586)
at coldfusion.compiler.cfml40.getToken(cfml40.java:11879)
at coldfusion.compiler.CFMLParserBase.isTrivialAngleBracket(CFMLParserBase.java:707)
at coldfusion.compiler.cfml40.jj_3_1(cfml40.java:9392)
at coldfusion.compiler.cfml40.jj_3_2(cfml40.java:9460)
at coldfusion.compiler.cfml40.jj_3R_67(cfml40.java:9500)
at coldfusion.compiler.cfml40.jj_3_86(cfml40.java:8147)
at coldfusion.compiler.cfml40.jj_3R_92(cfml40.java:8584)
at coldfusion.compiler.cfml40.jj_3_85(cfml40.java:8641)
at coldfusion.compiler.cfml40.jj_2_85(cfml40.java:7619)
at coldfusion.compiler.cfml40.cfml(cfml40.java:4215)
at coldfusion.compiler.cfml40.cfif(cfml40.java:311)
at coldfusion.compiler.cfml40.cfml(cfml40.java:4224)
at coldfusion.compiler.cfml40.cfelse(cfml40.java:442)
at coldfusion.compiler.cfml40.cfelseif(cfml40.java:374)
at coldfusion.compiler.cfml40.cfif(cfml40.java:314)
at coldfusion.compiler.cfml40.start(cfml40.java:4664)
at coldfusion.compiler.NeoTranslator.parsePage(NeoTranslator.java:667)
at coldfusion.compiler.NeoTranslator.parsePage(NeoTranslator.java:648)
at coldfusion.compiler.NeoTranslator.parseAndTransform(NeoTranslator.java:401)
at coldfusion.compiler.NeoTranslator.translateJava(NeoTranslator.java:343)
at coldfusion.compiler.NeoTranslator.translateJava(NeoTranslator.java:144)
at coldfusion.runtime.TemplateClassLoader$TemplateCache$1.fetch(TemplateClassLoader.java:418)
at coldfusion.util.LruCache.get(LruCache.java:180)
at coldfusion.runtime.TemplateClassLoader$TemplateCache.fetchSerial(TemplateClassLoader.java:362)
at coldfusion.util.AbstractCache.fetch(AbstractCache.java:58)
at coldfusion.util.SoftCache.get_statsOff(SoftCache.java:133)
at coldfusion.util.SoftCache.get(SoftCache.java:81)
at coldfusion.runtime.TemplateClassLoader.findClass(TemplateClassLoader.java:591)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:80)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:53)
at coldfusion.CfmServlet.service(CfmServlet.java:201)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42)
at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
at jrun.servlet.FilterChain.service(FilterChain.java:101)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
Hi
Try with a test code like an example provided :http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-7baf.html
Always provide the exact version of CF and share a sample code
VJ
Thanks Vishu,
We are running Coldfusion 9 and attach is the sample code and error message.:
The CFML compiler was processing:
A cfgrid tag beginning on line 39, column 18.
The error occurred in E:/Websites/DreData/sobrietytesting/main/Sobrietytesting/Admin/view_users.cfm: line 54
52 : hrefkey="member_id"
53 : bind="cfc:tabledisplay.browseAccessAcountRequests(,,,)"
54 : >
55 :
