There is nothing more difficult than to remotely troubleshoot
someone else's PC - except troubleshooting an
intermittent problem remotely, on someone else's PC.
That said, I would first check the resources on your PC to
see if it might be a local hardware or software problem. You seem
to have started that process.
Regarding hardware:
Do you have plenty of contiguous free HDD space available?
Is your CPU handling other graphic-intensive applications
okay?
Specifically, what make and speed of CPU are you running?
What does Task Manager read during your attempted recording
actions?
..... (CPU usage percentage) .....
How much RAM is installed on your development machine?
Are you working on a networked machine (workstation) or a
local?
From the software perspective:
What version of Captivate are you running?
What other applications are running simultaneously ....
..... (specifically, any that might capture the "PRTSCR" key)
Have you opened MSCONFIG to shut down Startup programs, then
rebooted?
..... (some other screen capture program may be running at
startup) .....
Welcome to the Captivate User Community, Mioutx!
