How to render Alpha + RGB in Adobe Media Encoder?
Engaged ,
Jan 21, 2015 Jan 21, 2015
I want to render a video.
Alpha;
RGB;
Alpha + RGB;
I can do in After Effects:
How to do this in Adobe Media Encoder?
Export or render , How to
262.8K
Adobe Employee , Jan 22, 2015 Jan 22, 2015
Hi Ti.S. Cavalcanti,
You have to make sure to set the bit depth to 32 bits. Note that only specific codecs allow you to do this.
Kevin
Adobe Employee ,
Kevin
Engaged ,
What happens if you put more bits? 48 or 64 for example.
What if I want to render only alpha, how do?
Adobe Employee ,
Hi ti.s.cavalcanti,
Good questions. Let me look into that for you.
Kevin
Engaged ,
Okay, Thanks, Kevin Monahan.
Engaged ,
Answer me at least how to render in just alpha. Please. Thanks.
Jan 23, 2015 Jan 23, 2015
Can you maybe explain a bit more about the workflow, what you wish to accomplish? When you say "just alpha", can I assume you mean a black and white image representing transparent and opaque areas? Which can be used as a "mask" later in a keying operation of some sort?
With older versions of Premiere such as CS6, one could change the Program Monitor settings from Composite to Alpha, then Export the alpha (black/white) video. With CC, that is no longer the case from what I can tell. Changing to Alpha mode shows the black and white alpha in Program, however exporting still exports the original image! In my mind, the Export should export what I am seeing in the Program monitor window, and not something else...
Anyway, if you are using the Ultra Keyer in Premiere CC, then you CAN Export the alpha, see attached pic. Key out the background of the clip, then change setting from "Composite" to "Alpha" and then Export. In the top example, if you Export from the timeline and choose a 32-bit codec (with alpha) for the export, then the alpha channel is included - the black area will be transparent. With the lower example, that would just be a 24-bit image, no alpha - the black and white areas represent transparent and opaque parts of the clip. The clip exported from the bottom could then be used as a "mask" layer to combine two other video clips using that mask clip as a guide. Please elaborate on what you want to do.
Jeff Pulera
Safe Harbor Computers
Engaged ,
Thanks! Good job!
Adobe Employee ,
Hi Jeff,
Thanks for confirming as to the way a video file with an alpha channel worked at one time. It's the same method I tried. This sounds like a bug. I'll look into it.
Best wishes,
Kevin
Engaged ,
Thanks.
Engaged ,
I want to do in "AME", the functions that have After Effects.
Are they?
RGB - Opaque = Colors / Transparent = black.
Alpha - Opaque = White / Transparent = Black.
RGB+Alpha - Opaque = Colors / Transparent = Transparent.
As in After Effects.
Adobe Employee ,
Hi ti.s.cavalcanti,
I found out from the After Effects team that you do not have the same options for exporting as you did with the render queue. Rendering out an alpha channel only file is not directly possible, but there is a workaround, as described here: Re: How to render out JUST Alpha in Media Encoder
Of course, the other two options are supported. I mentioned earlier how to export RGB+Alpha. Of course, you can export RGB only by switching the Depth setting to 24.
Kevin
Engaged ,
Thank you all! Now I understand everything.
Aug 07, 2019 Aug 07, 2019
what do to, when only 16-bit max is available and not 32-bit? export is from Character Animator.Exporteinstellungen.jpg
Enthusiast ,
Dec 20, 2022 Dec 20, 2022
Unfortunately, the link is broken.
Dec 26, 2019 Dec 26, 2019
I am running into the same issue when I try to render a ProRes 4444 file from Adobe media Encoder 2020. The maximum Depth I can render at is 16-bpc+alpha, and the rendered video processes in YUV colorspace rather than the RGB I need it to be. Any ideas?
Jan 02, 2020 Jan 02, 2020
I'm having this problem too!
Feb 07, 2020 Feb 07, 2020
Has anyone found a solution to this? I'm running into the same problem.
Feb 27, 2020 Feb 27, 2020
bpc: bits per layer
16 bits par couche= 3x16= 48 bits
+16 bits alpha = 64 bits ! that's a max
ProRes is a YUV codec
Mar 24, 2022 Mar 24, 2022
How do you get to this screen?
Jul 17, 2016 Jul 17, 2016
Well, I've found a different solution. In Media Encoder, I changed the format to quicktime, then in video codec, to PNG. Done. My videos with transparency in avi were almost 2gb. Now have only 20mb, and with the same quality
Engaged ,
Aug 05, 2016 Aug 05, 2016
Very good, thanks!
Oct 03, 2017 Oct 03, 2017
hey there.
i dont seem to have a png codec. please ellaborate
this was very helpful. i hope the software that will be used will open it up. ( the software is mix emergency / serato dj incase anyone was wondering ) thx again
