Locked
Adobe Air will not install
Jan 28, 2015 Jan 28, 2015
Adobe Air replies with and error message:
Sorry, and error has occurred while installing Adobe Air. Installation may not be allowed by your administrator. Please contact your administrator.
I have run as user and Administrator to no avail.
Most up to date version has been downloaded from Adobe.
Tried to delete any previous versions
No previous version of Adobe Air can be found on the computer.
I want to use an added program in Dreamweaver.
The add-on is XPOSE Gallery Image Manager
How can I install Adobe Air so I can use XPOSE Gallery Image Manager?
Installation
6.9K
Community Beginner , Apr 08, 2018 Apr 08, 2018
I finally found something that worked for me (Windows 10).
- After downloading the Adobe Air .exe file, go to its location (usually in your Downloads folder) and right click on it.  Rather than clicking on "Run as Administrator" (which did not work for me), click on "Properties".
- Then go to the "Compatibility" tab.
- At the bottom of the Compatibility tab place a check beside "Run this program as an Administrator".
- Hit the "Apply" button and try running your Adobe Air install again.
Note: After d
You may have better luck in the AIR Forums: AIR Installation Issues
You can download the full installer package from here:
<Adobe - Adobe AIR>
It should work.
Good luck.
Jan 29, 2015 Jan 29, 2015
Version 16 of Adobe Air was downloaded and install was attempted..
Unfortunate the same error message appeared:
Sorry, an error has occurred while installing Adobe Air. Installation may not be allowed by your administrator. Please contact your administrator.
Just tried Adobe Application Manager BUT
"We encountered the following issues:
Sorry there seems to be a problem with the installation process (Error code: A12E1).
For troubleshooting tips, please visit our support page."
Assuming that your machine is a Mac, this may help http://helpx.adobe.com/air/kb/unable-update-air-mac-os.html
Wappler, the only real Dreamweaver alternative.
Jan 30, 2015 Jan 30, 2015
Thank Ben Pleysier but I am PC and not Mac
Apr 27, 2018 Apr 27, 2018
No its dell
Feb 03, 2015 Feb 03, 2015
Computer Technician explored issue:
The Logitech Video driver (LVPrcSrv.exe) is known to cause issues with the installation of the runtime. If the application is loaded, end the process by selecting it from the Windows Task Manager.
here is another users findings, which with my knowledge of adobe products and their painful installs at times, this makes some sense:
Ok I figured out what the issue was, and I must admit I wish this were better documented.  Anyway, here are the details I posted in a Windows 7 forum:
It seems that I needed to run the .exe file with the "-uninstall" parameter once before trying to install again. Even though I had uninstalled through Windows 7 uninstaller, Revo uninstaller, and Microsoft Installer Cleanup, as well as cleaning out the registry thoroughly, it seems it wasn't getting uninstalled.
So, for anyone else with the same problem, try this:
1) Make a shortcut of the Adobe AIR installer executable.
2) Right-click the executable, go to properties, click on the "shortcut" tab.
3) In the "Target" field, add "-uninstall" (minus quotes) to the end of the existing text.
4) Run the file, and Adobe AIR will truly be uninstalled this time.
5) Now run the original installer file to install the program.
check those two things and tell me how it works out
My reply to Computer Technician:
G:\documents\Adobe\Adobe Air\AdobeAIRInstaller.exe-uninstaller
When clicked to open it only shows Adobe “Soundbooth Scores” folder
May need further on site assistance
Note: After doing this, I had to do the same steps for the program that I was initially trying to install that required Adobe Air as a pre-requisite.
