I have a 2006 iMac with OS 10.5.8. My default search engine is Safari 5.0.6. The hard drive crashed a couple of weeks ago, and I now have a new hard drive . . . one without the aps I used before.
The ap I'm having big problems replacing is Adobe Flash Player, without which I can't see the videos my friends put on Facebook.
I've been told that the latest version that will run on this OS is 10.3. I have gone into Adobe archives, downloaded this version of the Player onto my desktop, and each time I try to install it, I get the message "The application Install Adobe Flash Player quit unexpectedly." No matter where I get this Flash Player from, I get the same message, over and over.
Any thoughts about how to replace my Flash Player, so that I can see the videos and play Bubbles IQ?
Hi Joby,
Is you iMac a PowerPC or Intel system?
Maria
Intel, María.
Hi Joby,
Version 10.3.183.90 should work on your system. I tried it earlier and it installed without crashing. Have you tried doing a disk check on the file or your system to ensure that it's ok prior to installing?
As you know, 10.3.183.90 is very old and vulnerable to security breaches as it has not been updated since it's initial release in July 2013. Since you have an Intel system, it may be possible to update to 10.6 (Apple sells the install disk for $19.99) and install the latest supported version. You can Google 'upgrading 2006 iMac to Snow Leopard', or similar, and it'll return a bunch of stuff (I could post some here, but don't want to send you down the wrong road). If possible, I would go this route, instead of installing an old, vulnerable, version of Flash Player.
Maria
