Greetings,
I run WinXp Media Ctr, on a Dell XPS 410 2.9 Dual Core System with 4 Gig of Ram. I have the newest version of Firefox. When I go to check to see if any of my Plugin's are outdated, it flags the Adobe Flash Player Shockwave Flash 16.0 vulnerable 16.0.0.235.
Also it flags the "Outdated"
Adobe Flash Player Real Networks Real Downloader Pepper Flash Video Shim Plug-In vulnerable 1.3.3.66
When I download the file: install_flashplayer16x32_mssd_aaa_aih.exe and closed Firefox and Ran it, it said the Flashplayer installed ok. It gave me the same file name to install to fix the "Outdated" Flash video ship plug-in. After installing both, and Firefox claiming to have installed them correctly. I ran the Plug-in Status utility again, and it keeps saying the two are still outdated. It's not recognizing that the files have been updated.
I went to the adobe flash webpage and checked the version there, and it says I have the Current Version installed. So Firefox is not reading the correct version. I also notice frequently that shockwave flash player and Plugin-container crash a lot when there's a lot of tabs running while playing online games and/or facebook games. I've already gone to the Flash player settings window and maxed the storage for them.
What can I do?
Thanx,
Timby
Have you rebooted your computer since installing Flash Player? It's normally not required, but probably a good first step in this case.
If that's not working, you may need to do a fresh install (or a refresh) of Firefox.
I think the problem is that the Adobe file DESCRIPTION for the file you just downloaded is 16.0r0, but the actual file is the .296 version. (I think the .235 version is also vulnerable. I downloaded today and got the .296 version.)
we need Adobe to fix the file description. You can verify this by putting in the browser "about:plugins".
If you have the same issue I'm seeing you will see:
I've found I can't seem to remove Shockwave Flash 16.0.0.235 . I've run the uninstaller, gone into the Windows/system32/Macromed folder and removed the flash files there, I've restarted both Windows Xp and firefox and it still claims to see the Shockwave Flash 16.0.0.235 version 16.0.r0 in the add-ons manager Plugins Section.
