ColdFusion Search Dialog:
Search on Open Documents produces java.lang.NullPointerException
Works well with Search on Current Documents
Paid license.
Please Advice.
Can you please paste/add error screenshot for this issue?
Are you getting any error logging for this error there?
Could you show us the steps in your search process. I am unable to reproduce your settings when I open the Search menu in my version of Coldfusion Builder 3.
Ctrl+Alt+F>Scope: Open Documents
If this short cut doesn't work for you, look under CF Builder 3 Preferences > Keys > 'ColdFusion Search Dialog'
Thank you, TechFuser. I have experimented by searching on 'Open Documents', but am unable to reproduce the error. However, there indeed seems to be a problem. It failed to work for me either.
Like you, I got a NullPointerException. But that seemed to happen whenever I restarted ColdFusion Builder 3. The details are as follows:
CFBuilder Version: 3.0.0
Build: 292483
Message:
Unhandled event loop exception
Exception Stack Trace:
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4397)
at org.eclipse.swt.SWT.error(SWT.java:4312)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4145)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3762)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
at com.adobe.ide.coldfusion.rcp.intro.Application.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Caused by: java.lang.NullPointerException
at com.adobe.ide.coldfusion.appcodegeneration.runtime.views.ViewContributionService$1.run(ViewContributionService.java:113)
at org.eclipse.ui.internal.UILockListener.doPendingWork(UILockListener.java:164)
at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer.java:158)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
... 23 more
Session Data:
eclipse.buildId=unknown
java.version=1.7.0_55
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86
I then cleared the error log, opened 2 CFM files in the editor, and performed a search as you had done.
Builder proceeded to search the entire workspace. Even then, it failed to find the search text. When I examined the error log, I found it was populated by a pair of errors, which occurs 72 times. The errors are:
Please report this as a bug, including a link to this forum page
Cheers! I have voted for it.
