I am using Creative Cloud Packers to create a Presenter 9 MSI file (32Bit). The creation process seems to complete with no errors and I have the resulting installation material and MSI. I install the generated exceptions using the following command line:
ExceptionDeployer.exe --workflow=install --mode=pre --installLanguage=en_US
I then try and deploy the MSI using:
msiexec /i Presenter932.msi /qn
The installation fails, from what I can tell from the log files it fails with a 1603 error which is a 'Generic' error from the research I have done.
Following the exact same process with the 64-bit version of Presenter the installation works fine. However we do not use MS Office 64-bit here at the university. I have even recreated the 32-bit installer using CCP on a number of occasions but the problem still remains. Running the MSI directly (not via command line) results in the same error as well.
Is CCP generating a faulty MSI and what can I do about this?
Mark
Moving this discussion to the Adobe Presenter forum.
This thread may help. Look below the 'correct answer' to see the explanation and fix.
