Hi Everyone
I have been beating my head against the ball trying to set up Uberconference to work with Adobe Connector.
I have tried to set it up as an Audio Provider -- but I just can't figure out how to set up the dial-in steps properly.
Has anyone out there used Uberconference -- or any other 3rd party audio conferencing provider -- successfully.
Help is much appreciated!
Greg
THIS TOOK CARE OF THE PROBLEM!!!
Thank you so much for your help Jorma.
Greg
The dial in process would be exactly the same as if you were dialing into the bridge as a participant. Most of the time it needs the following steps.
Phone number: 800-555-5555
Delay: 3000 ms
DTMF: (passcode) 123456#
Delay: 3000ms
DTMF: 1 or # (for a roll call or to join the bridge)
However if the provider is not using a SIP compliant bridge, the Universal Voice tool will fail upon attempting to dial out.
Also, for the hosted environment, the phone bridge must have a toll-free number.
Greg
I'm thinking about using UberConference as the audio provider for Adobe Connect. Do I understand correctly from your response that I must have a toll-free number with UberConference in order to use it with AdobeConnect?
Having a toll-free number is an additional $10/month at UberConference, so it definitely affects the price of the service.
Hi Kris,
Yes, for the hosted environment the number should be toll-free.
