Lemme explain.
I just got Creative Cloud for a project I'm doing. Keep in mind we're on a relatively tight budget- it's a school project, but I'm not even in high school yet. So other alternatives are out- I'm NOT changing programs.
Well, I animate (or at least, I'll be learning to) in the style of hand-drawn animation. I don't like the way the computer moves shapes for me with tweens. My main issue is with sketching messy frames- I can't do it very well with the pen tool. Here's an example I did in Paint Tool SAI:
It's the difference between using pencil and pen- pencil on left, pen on right. Even if it looks pretty good, it's hard to do, and doesn't feel right. What would make things a LOT better is if, like I was told somewhere, I could tone down the brush opacity. That way, I could sketch like I do with the marker tool on SAI and it would be just as good. I'm using the latest version of Flash. Please help me! unu
Select the color fill, then type in the alpha level you want to use.
Hi Amelia,
Which device are you using Flash Pro CC on? This is the information I have from the team.
If you are using a pen, can you try switching to a mouse and let us know if you still have the same issues?
Preran
I'm using a Wacom Intuos. Nothing really changes except that I don't have pen pressure anymore. What I'm trying to do is lower the opacity of the brush, can you help me with that? Thank you!
Can you explain your problem a different way? I don't see what pressure and opacity have to do with eachother. And your drawing is from another program, which is probably just confusing me. The ability to turn pressure on is in the Tools panel, right below brush shape/size, and above the stylus tilt option.
Using pen in SAI is basically the same thing as using the brush in flash. I never said opacity had anything to do with opacity, my last post was in response to Preran.
Oh ok, sorry about that. You can always change the brush alpha level, but unless you are in Object Drawing mode or working on a specific new layer, it would just replace the brush strokes that were there before rather than automatically layer up in a Photoshop-like way. Hope that helps somewhat.
Thanks, how do I go about that?
Oh my god... YOU SAVED MY LIFE!!!!!!! THANK YOU THANK YOU THANK YOU OH BY SITHIS I DON'T KNOW HOW TO THANK YOU ENOUGH
You can change the alpha of the fill color, but it won't build up and get darker like the image on the right side unless you have Object Drawing enabled or add new layers to draw on.
