I'm trying out the new cfimage tag and I'm trying to loop
through a query to resize images to create thumbnails. I don't even
know how many different combinations I've tried. If you were trying
to resize just one image, the first set of lines of code is how you
would do it. The second set is what I've ended up trying to do.
What I don't understand is why the first image seems to work, but
the second one throws an error? I know there's probably a better
way of doing this other than using evaluate too. I've added a
debugging output just above the image in the first column to make
sure there wasn't an error in the variable I was trying to use.
This is the page if you want to see it in action:
http://67.199.23.10/adopt/dogs.cfm.
I really appreciate any help, because I've tried all I know to try
at this point. Thanks!!!
