Dear all patient helpers,
My current project is 're-furbishing' the FameMaker to EndNote' connection. This task comprises several steps:
For step 3 I have now researched a lot and found this:
docId = F_ApiGetId(0, FV_SessionId, FP_ActiveDoc);
params = F_ApiGetSaveDefaultParams();
i = F_ApiGetPropIndex(¶ms, FS_FileType);
params.val.propVal.u.ival = FV_SaveFmtFilter;
i = F_ApiGetPropIndex(¶ms, FS_SaveFileTypeHint);
params.val.propVal.u.sval = F_StrCopyString((StringT)"0001ADBEHTML");
So my interpretation of all this leads to this snippet:
var file = app.ActiveDoc;
SaveFileRTF (file);
function SaveFileRTF (file) {
var params = GetSaveDefaultParams();
var returnParamsp = new PropVals();
var i;
i = GetPropIndex (params, Constants.FS_FileType);
params.propVal.ival = Constants.FV_SaveFmtFilter;
i = GetPropIndex (params, FS_SaveFileTypeHint);
params.propVal.ival = "0001ADBERTF ");
file.Save(file.Name, params, returnParamsp);
return;
But alas, this reports a stange error: "Semicolon expected on line 13". Even If you help me to overcome this the next swamp lurks in step 4: how to open the RTF?
Hi Klaus, This works for me in FrameMaker 12. Please let me know if you have any questions or comments. -Rick
...#target framemaker
var doc = app.ActiveDoc;
saveRtf (doc);
function saveRtf (doc) {
var saveName, saveParams, retParams, i = 0;
// Get a property list to return any error messages.
retProps = new PropVals();
saveProps = GetSaveDefaultParams();
i = GetPropIndex (saveProps, Constants.FS_FileType);
saveProps.propVal.ival = Constants.FV_SaveFmtFilter;
Ah, at least line 12 should read
i = GetPropIndex (params, Constants.FS_SaveFileTypeHint);
And after spotting the superfluous ) at the end of line 13 - no error occurs,
but the script does nothing to an open/active doc
So what is missing?
Edit:
I notice that properties are starting lower case in the FM Object Reference.
So I change line 15 from
to
file.Save(file.name, params, returnParamsp);
But that has no effect.
Concerning the syntax
Using the FrameMaker 12 Ob ject model (chm) from Jongware as of 18-Jan-2015) i see this (the FM devnet is aged with FM10 scripting guide etc., however FrameMaker Support Center leads to the FrameMaker Learn & Support with the FM-12 Scripting Guide)
- In the FrameMaker 12 Object Reference properties start upper case (e.g. CurrentPage)
- Same is true for the methods there: AddText
- In the JS base classes properties start lower case (e.g. absoluteURI)
- Same is true for the methods there: concat
- For the Script UI classes the properties start lower case (e.g. parent)
- And the methods also start lowe case (e.g. drawOSControl)
IMHO this is more than tricky.
#target framemaker
saveRtf (doc);
i = GetPropIndex (saveProps, Constants.FS_SaveFileTypeHint);
saveProps.propVal.sval = "0001ADBIRTF ";
saveName = doc.Name.replace (/\.[^\.]+$/, ".rtf");
doc.Save (saveName, saveProps, retProps);
The key here is on line 17. Since the file hint is a string you have to use sval instead of ival. ival would indicate an integer data type; sval is a string.
Thanks Rick!
Compared to my code the difference is in providing the extension rtf in the file name. The sval was there already.
Hence my other test with a hardcoded target file name (containing that rtf) worked, but not the 'flexible' script.
I still have to learn to more carefully compare go and nogo situations...
