quote:
Originally posted by: Grizzly9279
It's a shot in the dark, but I'd seriously recommend setting "setclientcookies" to "YES". All sites that I've worked on have done this, and it is still very possible to set "in-memory" cookies (such that they expire immediately when the browser is closed)
did you every find a resolution for this problem? I am having the exact same problem ....
Steve, how "exact" ? You're also dumping the cookie scope and see no cfid or cftoken? Or do you just mean "people don't stay logged in" or something?
These kind of problems often have many different possible causes, so diagnostics are vital to know what is or is not happening.
And had I seen this thread when it was started 15 years ago, I'd have proposed that the folks involved should have dumped the cgi.http_cookie var rather than the cookie scope. The former is what reflects what cf GOT from the client, while the latter can reflect what cf SET on the server.
Further, I'd have challenged them to do that in a page in its own folder with a blank application.cfm or. cfc, to avoid some impact from any other in a folder/s above it.
You also are not likely using the browsers referred to then, but please confirm both what ones you Are seeing the problem with and also, when the problem happens for someone using one browser, does it happen also for that user in another, different browser?
And are these http or https requests? Are they all to the same domain or different subdomains? We could consider your cf admin settings for these session cookies, as well as your app's settings.
These problems involve LOTS of variables in the client and server side, as well as many moving parts.
The more you can share, the more likely we can try to piece together the evidence to get you to an explanation and solution to your particular problem.
