Hello,
I have a user who is using a laptop running Windows 7 (64-bit) and Office 2013 (64-bit). I installed Adobe Presenter (64-bit) for him, and it worked well until this week, when the Adobe Presenter tab disappeared.
When I go into the Add-Ins, I see it in the COM Add-Ins. I have removed it, and tried to re-add it, but it told me that the MenuLauncher.dll was not a valid Office add-in. I re installed Presenter, but that did not help.
When I log in to that computer, the Adobe Presenter tabs appears in PowerPoint for both of my profiles (admin, and regular domain user) but not for his profile. Can you tell me what I can do to fix it for this user?
Jen
Please create a new user profile for the user which has the complete admin rights and then try to use the Presenter.
If it still doesn't work then you need to remove it completely from the machine and then reinstall it. You may follow the instructions mentioned below for clean installation.
Disclaimer: The registry contains system-related information that is critical to your computer and applications. Before modifying the registry, be sure to make a backup copy of it. Adobe doesn't provide support for problems that can arise from improperly modifying the registry.
Rajeev.
Thanks! After checking all these various folders, and deleting any sign of Presenter, as well as the registry (found some extra folders in HKCU that I deleted as well) such as anything I came across that had to do with the Presenter PowerPoint Com Add-in. When I re-installed it, the user said he did have the Adobe Presenter tab. I am so glad this is solved.
