Adobe has not been able to resolve our company's connection problem with SharePoint thus far.
We do know that we can use TFS 2008 with RoboHelp because they have done that in the past. We are on RH11.
We need to know...Has anyone experienced any problems with using TFS 2008 with RH11? If so, what kind of problem(s)?
I've used TFS 2008/2010/2012 with RoboHelp without problems so far. You will always get the check in dialog, but that is the way it works, not a problem. This will become annoying when you are relocating lots of topics, since you will have to check in files a lot during these operations. But otherwise it works perfect in my experience.
As long as you make sure you have the 32 bit MSSCCI provider for the correct TFS version (MSSCCI 2008 for TFS 2008), you should be fine.
