10 Replies Latest reply on Feb 27, 2015 5:10 PM by Zantcor
    Fill array with file names
    Zantcor Level 1
      What am I missing?  I've got alerts that should pop up if it works and if it fails but instead it does nothing, I'm sure its possible to create an array that is made up of all the file names of a folder.  In the past I've had to enter all the values one a time and some of these folders have 200+ files in it.
      #target illustrator
      filltotesTempArr
       function filltotesTempArr()
      var toteTemparray = new Array(toteTemps)
      var toteTempPath = Folder ("S:/Illustrator JS Palette/Direct Template Calls/Totes");
      var allFiles = artPath.getFiles(order);
      var toteTemps
      if (allFiles.length > 0)
          for (i=0;i<allFiles.length;i++)
                  toteTemps = toteTemps + app.open(allFiles[i] )
                }//end for
            alert("Your array has the current values:" + toteTemps);
          }//end if
          else
          alert("Script to fill Totes Templates Array has failed");
        • 1. Re: Fill array with file names
          Silly-V Adobe Community Professional
          At the present state, I am not sure how this line would work.  What is artPath , and what is order?
          • 2. Re: Fill array with file names
            Zantcor Level 1
            I need to take all the files inside of a folder, and put their file names in an array like this;
            var totesarr1= new Array ("A165331","A165332","A165333","A165334","A165337","A165338","A165344","A165348", "A165349",
            "A165352","A165353","A203","A210","A211","A214","A222","A229","A231","A232","A234","A248","A250","A252","A268",
            "A271","A272","A278","A290","A292","A322","A323","A324","A325","A327","A330","A402","A404","A405","A407","A408",
            "A409","A410","A411","A414","A415","A417","A420","A422","A423","A424","A425","A427","A430","A436","A438","A439",
            "A440","A441","A443","A446","A448","A449","A450","A451","A452","A454","A455","A456","A460","A461","A468","A470",
            "A490","A495","A497","A500","A508","A509","A510","A512","A513","A514","A518","A524","A525","A526","A527","A530",
            "A533","A534","A536","A543","A581","A582","A587","A602","A619","A624","A705","A707","A710","A714","A715","A739",
            "A740","A741","A742","A743","A744","A745","A748","A750","A751","A752","A753","A754","A755","A756","A763","A800",
            "A801","A804","A806","A811","A815","A817","A818","A819","A824","A832","A835","A836","A838","A841","A844","A848",
            "A849","A852","A854","A856","A857","A859","A861","A863","A865","A866","A868","A871","A873","A877","A879","A881",
            "A885","A888","A890","A894","A899","A900","A902","A904","A940","A941","A943","A944","A945","A948","A97307","A97309",
            "A97313","A97314","A97315","A97316","A97321","A97326","A97340","A97342","A97708","A97715","F742","F751","V6432");
            so the closest thing that I can come up with is this;
            #target illustrator
            filltotesTempArr
            var order = new RegExp(input);
            var totetempnames = toteTempPath.getFiles();
            var totetemps = new Array ()
            var allFiles = toteTempPath.getFiles();
                        toteTemps = toteTemps + "," + app.open(allFiles[i])
                      }//end for
                }//end if
                else
            alert ("Script is Done")
            but even this dosn't work like it should
            #target Illustrator
            GetTempNames;
            function GetTempNames ()
            var toteTempNames = toteTempPath.getFiles()
            var totetemparr = new Array ( toteTempNames )
            alert ("script is done get ready");
                alert ("Here " + totetemparr);
            so now I'm at a loss
            • 3. Re: Fill array with file names
              Just try something like this:
              function GetTempNames(){
                var toteTempFiles = toteTempPath.getFiles();
                var namesArr = [];
                for(var i=0; i<toteTempFiles.length; i++){
                var thisFile = toteTempFiles[i];
                namesArr.push(thisFile.name);
                return namesArr;
              var myNames = GetTempNames();
              • 4. Re: Fill array with file names
                Zantcor Level 1
                #target illustrator
                filltotesTempArr
                            toteTemps = (allFiles[i])
                          }//end for
                      alert("Your array has the current values:" + totetempnames);
                    }//end if
                    else
                alert ("Script is Done" + filltotesTempArr()+ " Total Files")
                the above works but it displays one long string with all the spaces and gaps changed to %20 so I'm not sure how to proceed or if this is even possible.
                • 5. Re: Fill array with file names
                  The above may look like it's working, but it's really un-working.
                  Just will keep setting your variable you want to be your array, to the current file object inside you loop. You probably will have better luck editing my snippet and using that as a function to get your arrays.
                  • 6. Re: Fill array with file names
                    Zantcor Level 1
                    This works but how would I replace all the %20 with a space before it is placed into the array?
                    • 7. Re: Fill array with file names
                      CarlosCanto Adobe Community Professional & MVP
                      here is a way
                      namesArr.push(File.decode(thisFile.name));
                      another way
                      namesArr.push(thisFile.displayName);
                      • 8. Re: Fill array with file names
                        Zantcor Level 1
                        Yet again you two have come to my rescue.
                        I've tried using the object view of ExtendScript tool kit but it doesn't show examples of using the stuff in the coding.  Is there a place I can go to see all the options for a given object?  I've googled a couple of different sites but none of them show good examples or all the options for a given object.
                        • 9. Re: Fill array with file names
                          the best place to look for sample code is this forum...distant runner ups, the Scripting Reference and the Tools Guide
                          • 10. Re: Fill array with file names
                            Zantcor Level 1
                            I found a website that does what I wanted, yes they have examples that show it being used with HTML but it does show the commands used in a syntax for basic Javascript, just have to find the illustrator part of it out by your self.
                            JavaScript Tutorial
